PearlBlueGT Posted September 9, 2011 Share Posted September 9, 2011 I have quite a bit of ticking coming from passenger side of engine bay. Subaru mechanic said that cleaning injectors would help. Anyone else have done injector cleaning service. Usually it's like $60-100 service but I found a shop that does $14/injector service and it's like 10 mins away from me. How hard is it to take them off? Link to comment Share on other sites More sharing options...
bighaus90 Posted September 9, 2011 Share Posted September 9, 2011 They aren't too bad to get to. just make sure you are gentle and don't break them while pulling them out. Link to comment Share on other sites More sharing options...
frank_ster Posted September 9, 2011 Share Posted September 9, 2011 ticking ? and cleaning stopping them from ticking ? uh ? i could be wrong but i don't think cleaning them will stop them from ticking. and the ticking your sure is from injectors not the noisy valve train ? is your car running like shit at wot ? if not i wouldn't touch the injectors Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
bmx045 Posted September 9, 2011 Share Posted September 9, 2011 sounds like a load of BUUUUUUUUUUUUUUUUUUUUUUUULLSHIT Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 9, 2011 Author Share Posted September 9, 2011 ticking ? and cleaning stopping them from ticking ? uh ? i could be wrong but i don't think cleaning them will stop them from ticking. and the ticking your sure is from injectors not the noisy valve train ? is your car running like shit at wot ? if not i wouldn't touch the injectors No, not valvetrain, just had heads rebuilt by machine shops so I know it's not valvetrain. Engine is brand new, new short block, rebuilt heads, all new gaskets, belt/pump, oil pump. I know how noise valvetrain sounds. Injectors do tick when they open/close Why do they have service that cleans injectors then? And no it's not pouring a can of STP in your tank. You actually take injectors off and they put it on machine and flow test/clean them http://www.ptrsds.com/injectservice.html Yes, there's sock inside fuel tank but it doesn't clean all of the stuff off, there's still minuscule particles that get past the sock and with time (let's say 94K like on my car) they plug up tiny injector holes Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 9, 2011 Share Posted September 9, 2011 Don't we have fuel filters? Removing injectors and cleaning them with flow testing is legit. Dealer injector cleaning magic is snake oil, IMHO. Link to comment Share on other sites More sharing options...
SSpeed Posted September 9, 2011 Share Posted September 9, 2011 Usually they use BG products in those machines... if you really HAVE to do it, get a can of BG 44k and try that... quite a bit of ticking probably isn't injectors... Link to comment Share on other sites More sharing options...
frank_ster Posted September 10, 2011 Share Posted September 10, 2011 No, not valvetrain, just had heads rebuilt by machine shops so I know it's not valvetrain. Engine is brand new, new short block, rebuilt heads, all new gaskets, belt/pump, oil pump. I know how noise valvetrain sounds. Injectors do tick when they open/close Why do they have service that cleans injectors then? And no it's not pouring a can of STP in your tank. You actually take injectors off and they put it on machine and flow test/clean them http://www.ptrsds.com/injectservice.html Yes, there's sock inside fuel tank but it doesn't clean all of the stuff off, there's still minuscule particles that get past the sock and with time (let's say 94K like on my car) they plug up tiny injector holes if the injectors were plugged you would notice at wot . and dirty or clean is not going to change the sound of the injector. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
