browningr6 Posted September 8, 2011 Share Posted September 8, 2011 This is most likely a question that has been discussed but have tried searching and didin't seem to come up with the answer that i was looking for so here goes... Would it be ok to get adapters to run 05+ sti wheels? Will the spacing work out ok? And if so where is a good reputable place to get the adapters? Thanks!!! Link to comment Share on other sites More sharing options...
gholman12 Posted September 10, 2011 Share Posted September 10, 2011 Adaptors will most likely mean at least a 15mm spacer with some new studs, and a 15mm spacer under any context is bad news. Add in the lower offset of the STi wheels and you're in for some seriously fugged up wheel bearings. Save yourself the hassle and fuhgeddaboudit. Link to comment Share on other sites More sharing options...
