2008LegacyGT Posted September 2, 2011 Share Posted September 2, 2011 Would the rota grids 18/8.5 offset 44 run ok on my 2008 legacy gt? If not what do I need to do to run them? Link to comment Share on other sites More sharing options...
underground000 Posted September 2, 2011 Share Posted September 2, 2011 search you need: coils, a lot of fender rolling and pulling, negative camber, and stretched tires 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
mwm5094 Posted September 4, 2011 Share Posted September 4, 2011 I have 18x8.5 +48 rota svn slammed bc br coils. Top hats are maxed and camber is a little off with a mild roll. No rubbing. Your rears will clear by a mile with a roll itll be close without (im running spacers in the rear with my roll) Also, my tire size is 225/40/18. Hope this helps. Link to comment Share on other sites More sharing options...
joedirtae09 Posted September 6, 2011 Share Posted September 6, 2011 I have 18x8.5 +48 rota svn slammed bc br coils. Top hats are maxed and camber is a little off with a mild roll. No rubbing. Your rears will clear by a mile with a roll itll be close without (im running spacers in the rear with my roll) Also, my tire size is 225/40/18. Hope this helps. ^looks good man!! Im in Lorton also, I wish I could spot you! Link to comment Share on other sites More sharing options...
minitech Posted September 12, 2011 Share Posted September 12, 2011 Nice 225-40 is what i run on my car. Good size! Link to comment Share on other sites More sharing options...
Natas Posted September 14, 2011 Share Posted September 14, 2011 should be able to run these with just a fender roll, even fit 235/40 on them. stock suspension with lower spring will work too. Link to comment Share on other sites More sharing options...
93turbo2 Posted September 15, 2011 Share Posted September 15, 2011 I had Rota Gravels 18x8.5 +44 with 235/40/18, rolled fenders, coilovers, camber bolts, and -1.75* camber up front with no rubbing at all. Link to comment Share on other sites More sharing options...
W1CKED Posted September 23, 2011 Share Posted September 23, 2011 you need: coils, a lot of fender rolling and pulling, negative camber, and stretched tires ^^ Yes, no, no, no. 18x8.5 ROTA Grids...BC Racing BR Series Coilovers...NO fender rolling/pulling...235/40-18 Falken FK-452 tires. http://i50.photobucket.com/albums/f301/WickedThird/2011-05-28_11-57-06_656.jpg http://i50.photobucket.com/albums/f301/WickedThird/2011-07-23_11-46-29_404.jpg Link to comment Share on other sites More sharing options...
underground000 Posted September 23, 2011 Share Posted September 23, 2011 ^^ Yes, no, no, no. 18x8.5 ROTA Grids...BC Racing BR Series Coilovers...NO fender rolling/pulling...235/40-18 Falken FK-452 tires. must of been thinking the wider grids oops:spin: 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
W1CKED Posted September 26, 2011 Share Posted September 26, 2011 must of been thinking the wider grids oops:spin: You would be correct for 18x9.5. Link to comment Share on other sites More sharing options...
