worknlikeadog Posted August 27, 2011 Share Posted August 27, 2011 I was working on my car today and under the dash there are some plugs and clips that aren't plugged in. One looks like an OB2 port but I don't know what it would plug in to. Another is a black clip with two wires going into it, plugged in nothing. And finally there are two green clips both with only one wire going in. I plugged in these two and my check engine light started to flash. I was just wondering if Anyone knew what these wires are for and why they made my cel flash Link to comment Share on other sites More sharing options...
johnegg Posted August 27, 2011 Share Posted August 27, 2011 these are all diagnostic plugs. they are not supposed to be plugged into anything. the greens will test a bunch of stuff if plugged in to each other. AND they will throw about half a dozen trouble codes if you leave them plugged in. the black 6 pin with the 2 spare single pins are for flashing trouble codes for the trans TCU, the ABS and the SRS systems. you use the single wire pins to ground out the pins in the connector. you cannot screw it up, all the pins in the connector are for flashing codes. if you ground out the wrong one, no worries, just try another one. i think the other connector is for a select monitor or something like that. i'm not really sure. but i have never heard of any one using it. what year, model, trans is your car? Link to comment Share on other sites More sharing options...
worknlikeadog Posted August 27, 2011 Author Share Posted August 27, 2011 1996 L 5 speed ej22 Link to comment Share on other sites More sharing options...
xXChaosXx Posted August 29, 2011 Share Posted August 29, 2011 the second obd2 connector is just that i believe and yea the other wires do funny stuff there are two green ones that when you plug them in they kick your AC on and off haha Link to comment Share on other sites More sharing options...
Stang70Fastback Posted August 30, 2011 Share Posted August 30, 2011 Gotta love how people will plug things into each other without knowing what they do first. I recommend you don't do this with the electrical panel in your home... Link to comment Share on other sites More sharing options...
xXChaosXx Posted August 30, 2011 Share Posted August 30, 2011 haha yea they will learn when stuff blows up Link to comment Share on other sites More sharing options...
