jtslmn720 Posted August 26, 2011 Share Posted August 26, 2011 I come from the world of trucks were you can add 2 inches in width and 3 inches in height on your tires without a worry of any rubbing. In the new Legacy its not quite the same ha, I notice a lot less fender room. I have used the Hankook Optimo H727s previously and loved them so I wanted to put them on the Legacy. Problem is they don't make the 205/50R17 size that is stock. Smallest they go is 225/55R17 which is 1.6 inches taller and .8 inches wider. Anyone running anything similar to this without spacers? Thanks for your help Link to comment Share on other sites More sharing options...
boxkita Posted August 26, 2011 Share Posted August 26, 2011 According to the tire sizing bible http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html , you'll be quite tall @ 26.8 and throw off the speedometer reading. If you are running a stock wheel, the width shouldn't be an issue. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
