Heedz Posted December 5, 2011 Share Posted December 5, 2011 If I can get away with just a rebuild then I would like to try to get around 500-600 hp out of it. Good luck.... its still a subaru. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted December 6, 2011 I Donated Share Posted December 6, 2011 Need to unbolt the engine from its mounts and lift it with a hoist to take off the pan. The rear bolts are blocked by the crossmember otherwise. Of course, it's easier to do the uppipe if you lift the engine, too, so it might not be a bad idea. Harbor Freight sells reasonably cheap hoists (I got mine from them -- just don't forget to use a 20% off coupon). Link to comment Share on other sites More sharing options...
CALLAHANS Posted December 6, 2011 Author Share Posted December 6, 2011 I do have a cherry picker and a 2 post lift sou it should not be to bad to do it is more a matter of finding the time to do. Going to start on it tonight and see how far I can get. thinking i might also need to replace the gaskets on the intake. Link to comment Share on other sites More sharing options...
