Major difference between outback and legacy?
Is the major differences the raised suspension and the taller tires?
Other then the looks?
Im thinking if i cant find a legacy gt, then i could extend my search to a outback xt as well.
Then in the future, just put on some different wheels with lower profile tires.
Would that make the outback drive more like the legacy?
Almost entirely suspension related, and the flares/cladding.
My lowered Outback drives, mostly, like an LGT wagon.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
  • 2 weeks later...
The brakes are different, and I hear the final drive is different between the two. I'm in the exact same situation as you, but at this point I think I am actually leaning toward the OBXT for preference and not just for availability.
Is the OBXT just as fast as the LGT, or is there some difference that makes the LGT faster? I thought I read a couple reviews that put the LGT a second or so faster 0-60...
They are about the same, in terms of quickness. At least according to my logs.
We are at a disadvantage, because our wheel/tire combo is heavier. Therefore, our ride is a little rougher and response to throttle a little slower. But, ultimately, the differences are very subtle.
I looked a little more and found better numbers that put the two pretty much even for acceleration. I would guess the slightly higher final drive in the outback is to compensate for the larger tire diameter, giving a pretty similar RPM-speed ratio.
That's correct. I think our overall final is a LITTLE higher than the LGT, but I don't remember specifics.
