E.k.k 1 Posted August 3, 2011 Share Posted August 3, 2011 I noticed today that my passenger rear tire was low, naturally I aired it up at a gas station. When I got onto the interstate to head home, and got up to speed, my car began vibrating fairly hard, although the car drove the same, it had an annoying vibration. When I got home I checked lugs and made sure the wheel was on good and tight. Any ideas as to what would cause such a vibration? My closest thought would be wheel bearing had decided to go out? Thanks in advance Link to comment Share on other sites More sharing options...
Nrw Posted August 3, 2011 Share Posted August 3, 2011 My guess is the wheel needs to be re-balanced, or you bent the wheel seeing as how the tire needed air. Link to comment Share on other sites More sharing options...
E.k.k 1 Posted August 3, 2011 Author Share Posted August 3, 2011 Well, the air was not ridiculously low by any means. Thanks much I'll get it balanced and see if that solves the problem Link to comment Share on other sites More sharing options...
