Justin Forsythe Posted July 31, 2011 Share Posted July 31, 2011 I replaced the sending unit which has an access panel behind the rear drivers side seat under the carpet, but the fuel lines disappear into body and re emerge under the hood to the fuel filter. Is there an access panel to the pump underneath the car somewhere? Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 31, 2011 Share Posted July 31, 2011 Remove the rear seat and lift up the trunk carpeting. The pump is in the tank on the passenger side, under a domed cover held in place by 4 bolts (IIRC). Remove the cover, and you'll see the fuel lines attached to the pump assembly. Remove the hose clamps and CAREFULLY remove the lines (they'll spray fuel. I used to use a rag over the assembly to help mitigate spray into the car), and the dozen or so 8mm (?) bolts holding the assembly in the tank. Remove the assembly, making sure nothing falls in. Make sure you don't lose the rubber gasket between the tank and assembly. Do whatever you have to do with the fuel pump (I have a spare SS fuel pump, if you need it), and install is the opposite of removal. Let the pump prime before trying to start the car. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Justin Forsythe Posted August 1, 2011 Author Share Posted August 1, 2011 yep, there it is, Thank you. it is not priming on ignition. next step to check voltage going to pump. I may need to take you up on that offer. Link to comment Share on other sites More sharing options...
