mike2225 Posted July 28, 2011 Share Posted July 28, 2011 I have a friend who owns and exhaust shop and i had him make me a custom 3" cat back using my prodrive mufflers and ive been driving the car around and it feels like i lost a little bit of power over the stock catback.Is this normal?? I assumed bigger piping would free up back pressure and give it a little more power. Link to comment Share on other sites More sharing options...
W1CKED Posted July 28, 2011 Share Posted July 28, 2011 How much power? Link to comment Share on other sites More sharing options...
mike2225 Posted July 28, 2011 Author Share Posted July 28, 2011 Not much but i do notice in 1st and 2nd at low rpms it doesnt pull as hard as it used too..The only thing i can think of there may be a very small leak were the stock DP meets with the 3" flange Link to comment Share on other sites More sharing options...
TRSCobra Posted July 28, 2011 Share Posted July 28, 2011 Post turbo exhaust leaks won't affect power. Link to comment Share on other sites More sharing options...
mike2225 Posted July 28, 2011 Author Share Posted July 28, 2011 Its weird it feels like there is more back pressure than stock but i do love the way it sounds Link to comment Share on other sites More sharing options...
WhiskeyTango Posted July 28, 2011 Share Posted July 28, 2011 Was the loss of hp measured on the butt dyno? Link to comment Share on other sites More sharing options...
SSpeed Posted July 28, 2011 Share Posted July 28, 2011 The stock catback isn't bad for power, depending on how good your friend is fabricating maybe you've hurt flow? Freeing backpressure will have a more pronounced effect closer to the turbine. Link to comment Share on other sites More sharing options...
whitetiger Posted July 28, 2011 Share Posted July 28, 2011 bigger piping after the cats (catback)wont do anything if you still have the stock DP and cats still in the system. does the OP have stage 2 mods or is this just a catback on a otherwise stock car. Link to comment Share on other sites More sharing options...
mike2225 Posted July 28, 2011 Author Share Posted July 28, 2011 yes it was...I was looking for a perrin mid/y pipe or something comparable but for the $50 i paid for the catback and they welded in an o2 sensor bung i decided to let my friend make a custom one Link to comment Share on other sites More sharing options...
mike2225 Posted July 28, 2011 Author Share Posted July 28, 2011 bigger piping after the cats (catback)wont do anything if you still have the stock DP and cats still in the system. does the OP have stage 2 mods or is this just a catback on a otherwise stock car. I have a FMIC,UP,DP and EL headers in the garage im just waiting to here back from the tuner before i put all the parts on Link to comment Share on other sites More sharing options...
whitetiger Posted July 28, 2011 Share Posted July 28, 2011 well then, put all that stuff in and see then how it feels. Link to comment Share on other sites More sharing options...
mike2225 Posted July 28, 2011 Author Share Posted July 28, 2011 As soon as i get a date to get it tuned ill be putting it all on the night before Link to comment Share on other sites More sharing options...
natecr Posted July 29, 2011 Share Posted July 29, 2011 anytime you change a part that doesn't quite require a tune. air filter to high flow. cb... up pipe.. reset your computer... sometimes that helps a lot if she relearns a few things as they have changed. Link to comment Share on other sites More sharing options...
mike2225 Posted July 31, 2011 Author Share Posted July 31, 2011 anytime you change a part that doesn't quite require a tune. air filter to high flow. cb... up pipe.. reset your computer... sometimes that helps a lot if she relearns a few things as they have changed. I reset the ecu and drove it for a few hundred miles and the car drives and feels alot better now..thanks Link to comment Share on other sites More sharing options...
