StormLegacy Posted July 28, 2011 Share Posted July 28, 2011 Ok, can anyone show a picture of the location they ran their amp power wire through the firewall on a 2010-2011 Legacy with a manual tranny? The one that is available for an auto isn't available to us 6spd's due to the clutch reservoir taking the spot. I'm hoping that someone has some pics showing an alternate location. Thanks!! Here's a pic showing my clutch reservoir and why I'm unable to use that location: http://i1233.photobucket.com/albums/ff393/stormsylph/Amp%20firewall%20grommet/25783ca6.jpg Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted July 28, 2011 Share Posted July 28, 2011 i was wondering the same thing, i have a 6-speed trans too. I would like to find a spot on the fire wall so i can cut a hole large enough to use a bushing for a 0/1 gauge wire. Link to comment Share on other sites More sharing options...
StormLegacy Posted July 29, 2011 Author Share Posted July 29, 2011 I'm going to try the wheel well this weekend. Ill take pics... Link to comment Share on other sites More sharing options...
StormLegacy Posted July 30, 2011 Author Share Posted July 30, 2011 OK! I ran the amp wire this morning and found an easy spot for a 4AWG power wire. On the drivers side of the power booster is a light gray grommet. It is currently putting through two lines already, but there is an opening on the bottom of the grommet. From under the drivers dash, I used a small screwdriver to poke a hole through the grommet and then pushed the wire through. It's a snug fit, so no sealant is needed. WHEW! Much easier than I thought! I'm continuing to install through the weeken (taking my time and concealing every wire). Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted July 30, 2011 Share Posted July 30, 2011 go any pics of the location? Link to comment Share on other sites More sharing options...
SuperAkuma Posted July 31, 2011 Share Posted July 31, 2011 Thanks for the tip, Pics would be really helpful when I do my install in a few weeks. Link to comment Share on other sites More sharing options...
StormLegacy Posted July 31, 2011 Author Share Posted July 31, 2011 Notice there are two lines going to the driver side of the power booster. The black cable furthest to the right is my amp cable. There is a light gray grommet in which to feed through from inside of the car. http://i1233.photobucket.com/albums/ff393/stormsylph/245ac6d9.jpg http://i1233.photobucket.com/albums/ff393/stormsylph/4b78b471.jpg Link to comment Share on other sites More sharing options...
StormLegacy Posted August 4, 2011 Author Share Posted August 4, 2011 ^^^ pics Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted August 4, 2011 Share Posted August 4, 2011 thanks for the pics, and how did you run the cable to the trunk? Link to comment Share on other sites More sharing options...
StormLegacy Posted August 4, 2011 Author Share Posted August 4, 2011 I ran the cable down the drivers side under the carpet. Link to comment Share on other sites More sharing options...
9mm Posted August 9, 2012 Share Posted August 9, 2012 i'm soooo glad i found this. i was scratching my head in awe, almost considered having the wires done at a shop. *bump for DIY's w/ MT's! /\__/\ (='.'=) This is Cat. Copy and paste Cat (")_(") to help him gain world domination. Link to comment Share on other sites More sharing options...
ericthibeault Posted May 17, 2013 Share Posted May 17, 2013 Really glad I found it also (from RockTheBeef). Thanks to you guys, I'll do my install this week-end in a breeze. Link to comment Share on other sites More sharing options...
