mike2225 Posted July 26, 2011 Share Posted July 26, 2011 Im about to install my Invidia DP but before I do that I plan on wrapping it and would like to put in a O2 sensor bung for an WBO2 gauge.Where is the best place to put it?I see on some DP's that its located in the bellmouth but on the Invidia it has a cast bellmouth and im not sure if you can weld into that.Also will I have to grind the wastgate divider flush with the flange or will I be ok with the stock turbo? Link to comment Share on other sites More sharing options...
bmx045 Posted July 26, 2011 Share Posted July 26, 2011 You can drill a bunghole out further down the pipe. The diverter should be shaved flush with the rest of the bellmouth. Do it anyway. Link to comment Share on other sites More sharing options...
