gholman12 Posted July 25, 2011 Share Posted July 25, 2011 So I'll snap some photos of this tomorrow, but its super easy and works super well. My rear cupholders broke at the base and they would no longer stay closed. I could finagle them open, but they were basically all sorts of f@cked up and they got in the way of feet and luggage and everything (plus they looked like crap). What you need: 1 Bottle of 5 minute epoxy 1 package of velcro dots, black 1 small stick STEPS: 1) You've got to pull out the little rubber stoppers marked in blue in the picture (courtesy of AK_GT). They should pull right out. 2) Mix your epoxy 3) Apply epoxy to back of velcro dot with small stick, spread a thin layer evenly. 4) Wait a minute or two for the epoxy to begin to set 5) Apply velcro dot on top of hole where rubber stopper came out of and press hard (it is best to put the spikey velcro pieces in the blue circles and the soft ones in the red circles) 6) Repeat epoxy procedure with soft velcro dot, and then place it gently against the spikey velcro so they are velcroed together, and the epoxy faces out 7) Gently close your cupholder into the position you want it to stay (make sure it's lined up right) and then press VERY HARD for 5 minutes 8) Repeat steps 1-7 with the other side, and you're done! You now have velcro to hold your cupholders up! http://legacygt.com/forums/attachment.php?attachmentid=103049&d=1311636597 Link to comment Share on other sites More sharing options...
Jimblaz Posted July 26, 2011 Share Posted July 26, 2011 perfect. i have hated hearing that thing flop around back there. Link to comment Share on other sites More sharing options...
luvracn Posted September 23, 2011 Share Posted September 23, 2011 had the same problem, just paid the $35 dollars and got a new one from dealer. Dang Kids! Should have seen this fix first, oh well. Link to comment Share on other sites More sharing options...
