MilwaukeeMike Posted July 25, 2011 Share Posted July 25, 2011 I'm looking for the other wrench needed for cam gear removal. The exhaust? wrench was easy to find but I'm having trouble finding the other side. This motor needs to come apart asap. I need the tool or someone in southern Wisconsin that can just do it. http://i102.photobucket.com/albums/m112/newshoesat9/Cam-Pulley-Wrenches.jpg I need the wrench on the left side- or something that will work in it's place. Thank you for any help Mike Link to comment Share on other sites More sharing options...
bmx045 Posted July 25, 2011 Share Posted July 25, 2011 FYI, you don't need this piece if you loosen the cam bolts with the timing belt still on. High rated impact gun will spin these right off using this exact method. Possibly using a breaker bar to hold the crankshaft still... Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted July 26, 2011 Author Share Posted July 26, 2011 is there risk to damaging the belt? thanks Link to comment Share on other sites More sharing options...
bmx045 Posted July 26, 2011 Share Posted July 26, 2011 9/10 when you rebuild an engine you put a new belt on. use the old belt during the process. but no, never damaged one since the impact shocks it so quickly, and the belt being tight, doesn't give it enough time to skip. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted July 26, 2011 Share Posted July 26, 2011 If its being rebuilt you should be changing the belt anyways... damn too slow... Link to comment Share on other sites More sharing options...
bmx045 Posted July 26, 2011 Share Posted July 26, 2011 Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted July 27, 2011 Author Share Posted July 27, 2011 the belt was just replaced and tossed the old belt. found a belt off an old outback at the junk yard today that should work nicely Link to comment Share on other sites More sharing options...
xero287 Posted July 27, 2011 Share Posted July 27, 2011 dont risk it get the damn wrench lol Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted July 27, 2011 Author Share Posted July 27, 2011 dont risk it get the damn wrench lol Ok- where to get that wrench? Link to comment Share on other sites More sharing options...
MilwaukeeMike Posted July 27, 2011 Author Share Posted July 27, 2011 nm junk timing belt did the job Link to comment Share on other sites More sharing options...
