spyguy Posted July 18, 2011 Share Posted July 18, 2011 Need to swap out my lower control arms (bushings cracked). Is there a significant difference between the OEM and Spec B control arms? The Spec B. are aluminum and stronger, but will I really notice this difference? Link to comment Share on other sites More sharing options...
TRSCobra Posted July 19, 2011 Share Posted July 19, 2011 You'll probably notice more of a difference if you just have a shop press out your cracked bushings and press in some aftermarket ones. Quite a bit cheaper as well. Link to comment Share on other sites More sharing options...
spyguy Posted July 19, 2011 Author Share Posted July 19, 2011 You'll probably notice more of a difference if you just have a shop press out your cracked bushings and press in some aftermarket ones. Quite a bit cheaper as well. lol, thanks, i'm going that route... Link to comment Share on other sites More sharing options...
