Dsfa Posted June 6, 2005 Share Posted June 6, 2005 I just finished a full detail on my car. I put three coats of Wolfgang and One coat of S-100 and I know that some waxes have a cleaner in them and when you layer them you take the previous layer off . Is this the case with S-100 does it have a cleaner in it and can you layer it? Link to comment Share on other sites More sharing options...
OCDetails Posted June 6, 2005 Share Posted June 6, 2005 S100 doesn't have any cleaners. Many liquid waxes do just because they need so much solvent to get the carnauba soft enough to use. Paste waxes don't need nearly as much solvent and therefore don't usually do any cleaning unless stated on the jar. I would probably just suggest putting on a coat every 3 or 4 weeks. It does layer, but it doesn't really do much optically. You did wait the 24 hours between coats on the Wolfgang, right? Its not like a wax. It needs the 24 hours between coats to cure properly. There is a chemical process taking place on the surface when you use a sealant like that. If you interrupt it then you won't get the appearance or the durabilty that you should. I usually just put on one coat per weekend for a few weeks and then top with a wax every few weeks after that. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Dsfa Posted June 6, 2005 Author Share Posted June 6, 2005 I did wait the 24 hours between coats and the only mistake I think I made was that I used some quick detailer in between coats . It looks pretty good. Do you think the QD affected the curing/bonding? Link to comment Share on other sites More sharing options...
Dsfa Posted June 6, 2005 Author Share Posted June 6, 2005 Pics Link to comment Share on other sites More sharing options...
OCDetails Posted June 6, 2005 Share Posted June 6, 2005 As long as the QD didn't have any carnauba in it then you are fine. Wax creates bonding problems and QDs with even a little carnauba can cause issues. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Dsfa Posted June 6, 2005 Author Share Posted June 6, 2005 Meguire's NXT. I wonder if it does? Link to comment Share on other sites More sharing options...
Dsfa Posted June 6, 2005 Author Share Posted June 6, 2005 What about ptting some KLASSE over it ? Link to comment Share on other sites More sharing options...
OCDetails Posted June 6, 2005 Share Posted June 6, 2005 NXT tech wax definitely does contain cleaners. If the QD you used said "spray wax" then it has wax in it and isn't good to use between coats. As far as Klasse goes... you really should settle on a sealant and then stick to it. Layering several different sealants is obviously possible, but I've tried it before and I prefer the appearance of just one sealant at a time. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Dsfa Posted June 6, 2005 Author Share Posted June 6, 2005 Meguire's NXT. I wonder if it does?I was using Meguires QD the NXT between coats to clean it. I didnt want to wash it in between coats because I thought the water could mess up the curing process.Does it have Carnuba in it? Link to comment Share on other sites More sharing options...
OCDetails Posted June 6, 2005 Share Posted June 6, 2005 Check the bottle. If it says "Spray Wax" then yes, it does. I've only got the Tech Wax, Spray Wax, and Interior Protectant in my garage. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
