03subyR Posted July 14, 2011 Share Posted July 14, 2011 So after putting stock fuel pump assembly into place I notice gas smell and wetness around the seal cover for pump core. I took it out, tighten everything nothing works. It's leaking when car is off when fuel tank is under pressure. Don't know what to do. Is there some kind of sealant I could spray on? Thanks, Max Link to comment Share on other sites More sharing options...
Firepuma Posted July 14, 2011 Share Posted July 14, 2011 Did you tighten the seal down like you do a wheel? I had to go around mine quite a few times before I got all the slack out of bolts that hold the pump seal down. Try that, you may not have got it as tight as you think, I went really slow 3 cranks a bolt and it honestly took about 10 mins to take out all the slack- Link to comment Share on other sites More sharing options...
03subyR Posted July 14, 2011 Author Share Posted July 14, 2011 I am afraid of breaking them. I heard that they break very easy. Link to comment Share on other sites More sharing options...
Firepuma Posted July 14, 2011 Share Posted July 14, 2011 That's why I say go slow and work your way around and do not overtighten. Some reason or another you don't have the seal seared correctly- Link to comment Share on other sites More sharing options...
03subyR Posted July 14, 2011 Author Share Posted July 14, 2011 I am so frustrated with this. All my holes matched don't know why it does not seal correctly. This is second pump I installed on my car and never had an issue with previous assembly. I will try to tighten them little more. Link to comment Share on other sites More sharing options...
Rushin Posted July 16, 2011 Share Posted July 16, 2011 you most likely put the metal cover in the wrong way. I worked on the 2011 that i faced same issue. Link to comment Share on other sites More sharing options...
03subyR Posted July 17, 2011 Author Share Posted July 17, 2011 But there is only one way to place metal cover. It should line up with groves on the pump and it did. Link to comment Share on other sites More sharing options...
Rushin Posted July 17, 2011 Share Posted July 17, 2011 I think it can be flipped 180 degrees and not fit right. Link to comment Share on other sites More sharing options...
03subyR Posted July 17, 2011 Author Share Posted July 17, 2011 I will take a look at it. Link to comment Share on other sites More sharing options...
m sprank Posted July 17, 2011 Share Posted July 17, 2011 Make sure rubber o-ring is in proper orientation and between tank and ring. A pic might help. Link to comment Share on other sites More sharing options...
