cartman Posted June 4, 2005 Share Posted June 4, 2005 Hi All, I did a search for this, but came up with virtually nothing on vendors who carry silicone intake and intercooler hoses. I know that they are widely available for the WRX. Any vendor info? Thanks. Link to comment Share on other sites More sharing options...
litkaj Posted June 4, 2005 Share Posted June 4, 2005 http://www.perrinperformance.com/Products/Legacy/Inlet_Hose.htm http://www.perrinperformance.com/Products/Legacy/Radiator_Hose.htm Link to comment Share on other sites More sharing options...
SUBE555 Posted June 4, 2005 Share Posted June 4, 2005 The intercooler is hard mounted, no flex hoses in there like the WRX. Link to comment Share on other sites More sharing options...
Leonardo Posted June 6, 2005 Share Posted June 6, 2005 One more that hasn't looked under the hood Link to comment Share on other sites More sharing options...
SUBE555 Posted June 6, 2005 Share Posted June 6, 2005 That's right leonardo. I find it good knowledge to know your car and it's parts and dynamics fairly well before going for upgrades and knowing what each does. Then again, I'm more about function over form and want stealthy looking components that don't stand out. Know what you have and what needs to be upgraded to get what you need want out before going and searching for parts is my best advice. Link to comment Share on other sites More sharing options...
Leonardo Posted June 6, 2005 Share Posted June 6, 2005 Please, call me Leo! Link to comment Share on other sites More sharing options...
franklin Posted June 6, 2005 Share Posted June 6, 2005 other than a sharp look do these have any functional improvement? Link to comment Share on other sites More sharing options...
SUBE555 Posted June 7, 2005 Share Posted June 7, 2005 The silicone turbo inlet pipe actually helps flow up top slightly and smooths things out a little. Compare the two and you'll understand, not the easiest install by any means though, the silicone inlet pipe that is, at least first time around, I'd gather would get easier on my second or third try. Particularly when tuned I'd say it should aid a bit up not, not significantly, but definitely noticeable. Think of your engine as a giant air pump, want to get air in and out as smoothly and efficiently as possible. Link to comment Share on other sites More sharing options...
litkaj Posted June 7, 2005 Share Posted June 7, 2005 The silicone turbo inlet pipe actually helps flow up top slightly and smooths things out a little. Compare the two and you'll understand, not the easiest install by any means though, the silicone inlet pipe that is, at least first time around, I'd gather would get easier on my second or third try. Particularly when tuned I'd say it should aid a bit up not, not significantly, but definitely noticeable. Think of your engine as a giant air pump, want to get air in and out as smoothly and efficiently as possible. So my question is, is it worth $250 for what you have described as a minor upgrade (especially since it leaves a good chunk of crappy pipe between it and the stock air box)? Link to comment Share on other sites More sharing options...
rc0032 Posted June 7, 2005 Share Posted June 7, 2005 So my question is, is it worth $250 for what you have described as a minor upgrade (especially since it leaves a good chunk of crappy pipe between it and the stock air box)?As your first mod no. When you are swapping turbos yes. Link to comment Share on other sites More sharing options...
SUBE555 Posted June 8, 2005 Share Posted June 8, 2005 I just did it since it is something I'll need to be donig anyhow, I know at the current stage it will make little difference though where I'm going it will make more of a difference, that is likely with a new turbo. Link to comment Share on other sites More sharing options...
