adidamtb Posted July 7, 2011 Share Posted July 7, 2011 Installed perrin intake a few months ago on 05LGT and have a question... during medium to heavy load I can hear the air flow is smooth until about 4k rpm when the air flow sounds like it's sputtering until 5 1/2k rpm where it goes back to being smooth. Is this a problem/normal or just need a tune? I'm a noob subie/turbo owner but glad to be finally part of the pack! Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted July 7, 2011 Share Posted July 7, 2011 You need to rescale the intake to work properly. Your Mass AirFlow sensor reads the amount of air based off of the diameter that it thinks. Throwing a new intake on changes the diameter so the car thinks its flowing less air than its actually taking in. Link to comment Share on other sites More sharing options...
blongo804 Posted July 7, 2011 Share Posted July 7, 2011 That's probably the wastegate flutter you're referring to. I can't help much further but i'm pretty sure that's it. I used to have the intake myself. If I remember correctly, you'd hear it sucking air, flutter, then i'd shift and it'd go back to sucking sound? Pretty sweet sounding intake but it's tough to tune via e-tune. Link to comment Share on other sites More sharing options...
adidamtb Posted July 7, 2011 Author Share Posted July 7, 2011 You need to rescale the intake to work properly. Your Mass AirFlow sensor reads the amount of air based off of the diameter that it thinks. Throwing a new intake on changes the diameter so the car thinks its flowing less air than its actually taking in. How would I go about rescaling intake? I sense I need a tune and feel I'm in over my head... Good thing I still have stock stuff. Link to comment Share on other sites More sharing options...
bmx045 Posted July 8, 2011 Share Posted July 8, 2011 I strongly recommend getting tuned if you're using anything but a stock intake. Link to comment Share on other sites More sharing options...
