Insurgent Posted July 5, 2011 Share Posted July 5, 2011 ok so i went back to stock on my car and need to put a stock or stg1 map on the car. i never had my stock rom as i've gotten a couple opensource tunes and never thought about getting my stock map. i have flashed roms before (i have romraider and ecuflash setup on my laptop w/ the tactrix) putting a map my latest tuner sent me to drive the car 100 miles to get tuned. i had different injectors for that one. i looked in the romraider forums for mickey's stg1 map and found spreadsheet version of it. it appears i would connect my cpu via ecuflash and read the rom and save it to my cpu. i would then copy/paste the parameters in mickey's map over what is in my current map. where does enginuity come in? question is, since i'm terribly unfamiliar with tuning, i dont know if the map in my car is a good starting point where maybe there are things modified that mickey's map doesn't touch. having never done the copy/paste thing, i'm really apprehensive to do that. does anyone have a stock or mickey stg1 map in ecuflash format (.hex?) that i could source? i saw testes map but in california i only have 91 oct... thanks for your time. Link to comment Share on other sites More sharing options...
bmx045 Posted July 5, 2011 Share Posted July 5, 2011 if you find out the ECU version we can find a stock map to send to you. It's easier to download a complete map and flash it to your ecu rather than edit yours. I haven't dealt much with that forum...I do know they supply base maps (complete maps) to flash. To get the version/ID you open up your map in RR ecu editor and click View -> properties and it shows the alphanumeric ID. I have a couple 05 LGT MT stock maps floating around... Link to comment Share on other sites More sharing options...
Insurgent Posted July 5, 2011 Author Share Posted July 5, 2011 pm sent Link to comment Share on other sites More sharing options...
jproy12 Posted July 5, 2011 Share Posted July 5, 2011 If you need it I have an '06 manual LGT map as well in hex mode! Good luck! JP Link to comment Share on other sites More sharing options...
