stoggy Posted July 4, 2011 Share Posted July 4, 2011 So I bought a new set of H&R springs (PN 29443) and was given a set of new OEM struts from a buddy. Can I put the new lowering springs right on the OEM struts without replacing top hats? I read a few install guides and they all use GR-2 struts with STi top hats. I wondered if the STi top hats only apply to the GR-2's only or not. I've put lowering springs on stock struts on other vehicles I just need to know if the same goes for Subaru's or not. Thanks everyone. Cheers. Link to comment Share on other sites More sharing options...
stoggy Posted July 5, 2011 Author Share Posted July 5, 2011 Anybody have any idea? Link to comment Share on other sites More sharing options...
sixspeedlegacy Posted July 6, 2011 Share Posted July 6, 2011 from what I have read you need impreza spring perches because its the spring shape that is tapered at the top. So you just need the new spring perch and not the actual strut top(part with 3 studs in it). Ben Link to comment Share on other sites More sharing options...
stoggy Posted July 9, 2011 Author Share Posted July 9, 2011 Yeah Ben you're right. I got the springs yesterday and took a quick peek under the wheel well and the Legacy stock springs are definitely not tapered. I'll order up the right spring perch...they're only $12 anyways from Subaru. Thanks again. Link to comment Share on other sites More sharing options...
