HpJunkie Posted June 21, 2011 Share Posted June 21, 2011 I have the whole thing installed and damn it was B****. One hose is two short and wont make it to the top port, nothing a connector and hose wont fix but anyways to my question. I have unplugged the PCV sensor and pipe. GMS doesnt have a port for it. I jumpered the sensor with the metal tab inside, but now what do you do with the open hose. Cap it or something? YES Ive already searched a ton and nothing just perrin threads. Thanks Link to comment Share on other sites More sharing options...
cd_legacy Posted June 21, 2011 Share Posted June 21, 2011 Not sure about the GMS inlet but with the Perrin inlet, remove the sensor completely from the hose, use the jumper in the harness, connect hose to supplied elbow and install in the top port on the inlet..hope this helps. Link to comment Share on other sites More sharing options...
HpJunkie Posted June 22, 2011 Author Share Posted June 22, 2011 There is no port on the inlet hose Link to comment Share on other sites More sharing options...
HpJunkie Posted June 22, 2011 Author Share Posted June 22, 2011 Anybody. Nobody knows? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted June 23, 2011 Share Posted June 23, 2011 I would remove the whole PCV assembly and run that crankcase vent to a catch can. It will delete that whole PCV assembly, delete the PCV "sensor" and clean up your intake tract. Link to comment Share on other sites More sharing options...
HpJunkie Posted June 23, 2011 Author Share Posted June 23, 2011 Actually have a catch can on the way. Will do thanks for the idea Link to comment Share on other sites More sharing options...
HpJunkie Posted June 30, 2011 Author Share Posted June 30, 2011 Ok so I grabbed a catch can. Question now is this. I ran the PCV hose around the motor to my catch can now I have to connect the catch can to the intake somehow to keep the system closed. The GMS inlet has no other connection. Could I TEE my catch can back into the Evap Selenoid Hose thats already connect to the inlet. Does the PCV hose blow air and the evap hose suck air or what are there functions. I need to connect my catch can to something now on the intake but what? Link to comment Share on other sites More sharing options...
