gholman12 Posted June 16, 2011 Share Posted June 16, 2011 So I posted this in the wheels subforum but I'm pretty sure no one goes in there... ever. I'm picking up a set of 17x7 et55 stock Outback Sport rims and I currently have some 17x7 et45 wheels on the wagon and like the more flush look of et45 over et55. So I want to add some small spacers to bump the wheels out a bit. Can I add 5mm spacers with the stock lug bolts? 7mm? 10mm? How hard is it to replace stock lug bolts with longer lug bolts? Ideally I think I'd go for between 5 and 7mm of spacer, but I won't know for sure until I get the wheels mounted. Thanks! Link to comment Share on other sites More sharing options...
black318i Posted June 16, 2011 Share Posted June 16, 2011 Not a good idea since the lug nuts don't thread on too far to begin with. The front studs aren't hard to replace, but I don't know about the rear. Link to comment Share on other sites More sharing options...
browningr6 Posted June 16, 2011 Share Posted June 16, 2011 also interested? Link to comment Share on other sites More sharing options...
Drift Motion Posted June 17, 2011 Share Posted June 17, 2011 you'll be fine with the 5mm, 7mm is a bit "on the line" look into a 15mm bolt on spacer, no extended lugs needed Link to comment Share on other sites More sharing options...
gholman12 Posted June 17, 2011 Author Share Posted June 17, 2011 Awesome - thanks! Link to comment Share on other sites More sharing options...
Drift Motion Posted June 17, 2011 Share Posted June 17, 2011 but be prepared to have premature bearing failure Link to comment Share on other sites More sharing options...
jagcars26 Posted June 19, 2011 Share Posted June 19, 2011 but be prepared to have premature bearing failure This /\ Link to comment Share on other sites More sharing options...
