AnthonySzum Posted June 15, 2011 Share Posted June 15, 2011 I have a hid kit from DDM Tuning. 35w 5000k setup. I was told my the dealer that some Subaru's have a weak spot in the stock wiring and can cause a fire because the HID pumps out too much power and the stock wiring harness cant handle them. Has anyone heard of this? I have them installed in the fog lights now and going to install them in the low beams next week. Any input is seriously appreciated. It would be going in a 2011 Legacy 3.6R limited. Thanks in advance guys, -Anthony Link to comment Share on other sites More sharing options...
W1CKED Posted June 15, 2011 Share Posted June 15, 2011 I just did a SEARCH for "HID" + "fire"...and got no results. Well...other than people talking about the bulbs "firing up". I think about 85%-90% of the members here have HIDs, so if there was a fire issue it probably would've been posted by now. Link to comment Share on other sites More sharing options...
laz Posted June 15, 2011 Share Posted June 15, 2011 I had HID's for years, and just now installed the DDM kit since my other kit died. Never a fire, but sometimes one fails to fire up! X --- Link to comment Share on other sites More sharing options...
300zx2g35 Posted June 15, 2011 Share Posted June 15, 2011 The only time HIDs pull more power is during initial start-up. After the bulbs are warmed up they actually pull less power than most halogen bulbs. There is a slim chance for fire in any car that didn't originally come with HIDs during that initial start-up but it's very rare. If you're that worried about it you can always get an aftermarket wiring harness which is designed to handle HIDs. Link to comment Share on other sites More sharing options...
kongzilla Posted June 15, 2011 Share Posted June 15, 2011 OP, tell that to the STI owners. Link to comment Share on other sites More sharing options...
blaze741 Posted June 15, 2011 Share Posted June 15, 2011 Aren't there wiring harnesses available? I am on stock wiring. Tons of members have been on stock wiring for years, no huge problems. Link to comment Share on other sites More sharing options...
AnthonySzum Posted June 16, 2011 Author Share Posted June 16, 2011 Thanks guys. This is probably a dumb question but is the fog light lens from the outside supposed to be ridiculously hot to the touch? My headlight isn't hot and I dont remember the fog lights on my other car being this hot. BTW, this is my first subaru and love it. Link to comment Share on other sites More sharing options...
mk6933 Posted June 16, 2011 Share Posted June 16, 2011 If you go with 35W, you are fine. If 55W, then its "suggested" that you will need harness. Link to comment Share on other sites More sharing options...
Pinky Posted June 21, 2011 Share Posted June 21, 2011 1st- Don't listen to ANYONE at the dealer when it comes to modding your car. Period. 2nd- The fuse would blow before anything would catch on fire. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted June 23, 2011 Share Posted June 23, 2011 1st- Don't listen to ANYONE at the dealer when it comes to modding your car. Period. 2nd- The fuse would blow before anything would catch on fire. Correct, unless the wrong value fuse was used... Link to comment Share on other sites More sharing options...
Pinky Posted June 23, 2011 Share Posted June 23, 2011 Also correct, but if you keep blowing the fuse and put a larger fuse in to fix the problem, you're not fixing anything. At that point, the problem isn't the fuse, it's the operator. Link to comment Share on other sites More sharing options...
RichieT81 Posted June 29, 2011 Share Posted June 29, 2011 My foglight lens is hot to the touch with the stock bulb in it (gen 5 leggy). Most of the hid kits are 35 watts which pull less power than the factory 55 watt bulb. Unless (like stated above) you go with the 55 watt hid kit you will need a harness upgrade (that kinda doesn't make sense does it, lol). All of the power for the hids is formed in the ballast which then ignite the gas in the bulb. Dealerships like to point fingers at everyone but themselves. I deal with multiple dealerships all the time, it goes on everywhere. But be nice to them cuz they can screw you, lol Link to comment Share on other sites More sharing options...
