gstreev Posted June 13, 2011 Share Posted June 13, 2011 I bought my 05 LGT new in 06 as a leftover. On my drive home I noticed brake vibration when applied over 45 MPH. Dealer cut rotors, came back again, dealer cut them again. When I needed pads I replaced the rotors front and back. This time I tired some cross drilled rotors on the front, 15K later the vibration is back. I guess you cant cut these so new rotors again? Could there be some other problem, wheel bearing, binding caliper? I thinking about this kit that uses Wilwood calipers, rotors, pads, SS lines for $869. http://www.revolutionbrake.com/production-brake-kits.html Has anyone used these and will the fit my stock rims? Or should I just go back to another set of non drilled or slotted rotors/ I drive pretty hard, but I don't track or autocross & at 79K I'm still on the original clutch. I never had a car with brake vibration like this and this is like nearly my 20th turbo / performance car. Link to comment Share on other sites More sharing options...
RochNY91TSI Posted June 13, 2011 Share Posted June 13, 2011 Your brake pads are leaving deposits on the rotors, get new brake pads and follow a good bed-in procedure to clear off the deposits Link to comment Share on other sites More sharing options...
gstreev Posted June 13, 2011 Author Share Posted June 13, 2011 Your brake pads are leaving deposits on the rotors, get new brake pads and follow a good bed-in procedure to clear off the deposits Great, I'll try that. Link to comment Share on other sites More sharing options...
W1CKED Posted June 13, 2011 Share Posted June 13, 2011 I thinking about this kit that uses Wilwood calipers, rotors, pads, SS lines for $869. http://www.revolutionbrake.com/production-brake-kits.html They don't list anything for Subaru... Link to comment Share on other sites More sharing options...
gstreev Posted June 13, 2011 Author Share Posted June 13, 2011 They don't list anything for Subaru... They don't but Ebay does and its the same company that sells them on Ebay. http://cgi.ebay.com/ebaymotors/Big-Brake-Kit-LEGACY-Subaru-13-4-piston-Wilwood-calpr-/150603284591?pt=Motors_Car_Truck_Parts_Accessories&hash=item2310a7c06f Not the right brake kit for you? Well, we have over 1200 different big brake upgrades some of which are available in our eBay store and at the revolutionbrake website. Or call one of our friendly reps with your specific needs at 541-488-5638. If we don't have the brake kit you need, we'll make it just for you. Link to comment Share on other sites More sharing options...
gstreev Posted June 13, 2011 Author Share Posted June 13, 2011 mayne someone can contact them and put a group buy together. I missed the boat, had an Ebay 10% off coupon that expired today. Link to comment Share on other sites More sharing options...
iNVAR Posted June 16, 2011 Share Posted June 16, 2011 Your brake pads are leaving deposits on the rotors, get new brake pads and follow a good bed-in procedure to clear off the deposits He means get new DIFFERENT brake pads. Not the same crappy OEM ones. Link to comment Share on other sites More sharing options...
