MadMaf Posted June 1, 2005 Share Posted June 1, 2005 Hi, Newbie here with near zero competencies in mechanics! Where can I find a walkthrough on how to change headlight bulbs on my 2000 Outback? Many thanks MM Link to comment Share on other sites More sharing options...
Jedi Pimp Posted June 1, 2005 Share Posted June 1, 2005 Just open the hood and twist the round plastic cover behind the headlight until it pops off. Pull off the headlight harness wires and move the spring clip. Then take out the bulb. When installing don't touch the glass capsule part of the halogen bulb or you will transfer oils from your fingers which will cause it to burn out early. If you do touch the glass by accident, clean with alcohol. Link to comment Share on other sites More sharing options...
MadMaf Posted June 1, 2005 Author Share Posted June 1, 2005 Sweet! Thanks JP - much appreciated. MM Link to comment Share on other sites More sharing options...
