lee07 Posted June 7, 2011 Share Posted June 7, 2011 Where is the water Valve for the A/c that opens and closes? How difficult is it to change? My a/c blows cold air for about 5 mins then suddenly starts blowing warm/hot air. All this after I went to get it recharged! You think it may be something else causing this issue! Link to comment Share on other sites More sharing options...
ouch1011 Posted June 8, 2011 Share Posted June 8, 2011 Make sure your cooling fans are coming on when you turn the A/C on. If so, I'd say they overcharged it, especially if they are blowing on high speed and it still isn't cooling. Link to comment Share on other sites More sharing options...
frank_ster Posted June 8, 2011 Share Posted June 8, 2011 water valve ? there is a pressure valve that has to be met for the a/c to come on.. # 1 when its blowing hot air is the compressor running ? the the small pipe going into the fire wall cold ? you may have a freezing issue also. where they may of accidently pumped a bunch of water into the system. because there probably dumbasses Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
