mazdaslo Posted August 14, 2012 Share Posted August 14, 2012 http://www.mcmaster.com/# 53175K21 this is the 8mm size, you need 4 of them 53175K24 this is the 11mm size, you need 3 of them 53175K25 this is the 12mm size, you need 10 or so 53175K26 this is the 13mm size, you need 5 of them Front of Intake BOV does it take forever, yes, will nothing ever, ever pop off again, we shall see I did have to do all this while my upper intake was off to replace the Upper to TGV gaskets, but they are all stainless, so they are pretty, and will stay that way If there is anybody in the SF Bay area that needs help with any of this, I now have a fantastic level of expertise in the subject of everything induction related, and am willing to help, for a sushi dinner. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 14, 2012 Author Share Posted August 14, 2012 Don't worry, some other vacuum hose is bound to pop off in another year. http://www.mcmaster.com/# 53175K21 this is the 8mm size, you need 4 of them 53175K24 this is the 11mm size, you need 3 of them 53175K25 this is the 12mm size, you need 10 or so 53175K26 this is the 13mm size, you need 5 of them Front of Intake BOV does it take forever, yes, will nothing ever, ever pop off again, we shall see I did have to do all this while my upper intake was off to replace the Upper to TGV gaskets, but they are all stainless, so they are pretty, and will stay that way If there is anybody in the SF Bay area that needs help with any of this, I now have a fantastic level of expertise in the subject of everything induction related, and am willing to help, for a sushi dinner. Which one do you guys think will most likely be next to pop off? Link to comment Share on other sites More sharing options...
FJuan Posted August 14, 2012 Share Posted August 14, 2012 As long as you have the "T" fittings & BPV zip tied, you should be good to go for a while. Only when you start disconnecting other hoses, for whatever reasons, is where you need to be concern. When you break the seal of the other hoses, they become a little looser. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 14, 2012 Author Share Posted August 14, 2012 As long as you have the "T" fittings & BPV zip tied, you should be good to go for a while. Only when you start disconnecting other hoses, for whatever reasons, is where you need to be concern. When you break the seal of the other hoses, they become a little looser. thanks for the info. I will then zip tie the hose on the BPV. I have not done that one yet and it is an easy one to do. Link to comment Share on other sites More sharing options...
