PearlBlueGT Posted June 6, 2011 Share Posted June 6, 2011 Our GT needs A/C recharged, anyone know what's PSI it's supposed to be at? I have a kit that I recharge my cars with. Link to comment Share on other sites More sharing options...
SCOBARU Posted June 7, 2011 Share Posted June 7, 2011 not to sure on the psi's but look under the hood there's a sticker, that shows the maximum amount of 134a that should be in there, but that's supposed to be a sealed unit so you may want to check for leaks in your system Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 8, 2011 Author Share Posted June 8, 2011 I didn't see sticker, might be missing it. I know its usually underside the hood or on the radiator support but it's not on either location. Where else could it be at? Link to comment Share on other sites More sharing options...
1454 Posted June 8, 2011 Share Posted June 8, 2011 Alldata might have it, or call the dealer. Mine was .88 +/- .05 Just a recharge is not always the best though. You really need to vacuum it. Link to comment Share on other sites More sharing options...
mwiener2 Posted June 8, 2011 Share Posted June 8, 2011 The correct pressure changes depending on temperature. You need a chart, not a single number. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ouch1011 Posted June 8, 2011 Share Posted June 8, 2011 If you want the A/C to work properly, take it to a qualified repair shop (i.e. not a quick lube) Most shops do special pricing during the spring/summer for A/C services. Link to comment Share on other sites More sharing options...
frank_ster Posted June 8, 2011 Share Posted June 8, 2011 charge it untill it works ! duh !! propor ac shops are usualy some 17 year old kid that is to lost to work at walmart Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
