Lucas Posted June 4, 2011 Share Posted June 4, 2011 Saw that one of the wires on the IACV was broke open and exposed copper showing. Took the top part of the valve off the magnet part I guess. Spliced a new connector put it all back together in the same spot and not it idles at like 2100 rpm. I let it idle for like 5-10 mins to see if it would readjust but nothing just idles super high.. Anyone know what I should do? I have a spare computer should I try changing them? It's a turbo model incase that helps Link to comment Share on other sites More sharing options...
ehsnils Posted June 4, 2011 Share Posted June 4, 2011 I suspect that the valve connection is bad some way. Did you measure it with a multimeter before you connected it? Link to comment Share on other sites More sharing options...
Lucas Posted June 4, 2011 Author Share Posted June 4, 2011 put a test light on all the wires and the light comes on. unfortunately i dont have a multimeter. Link to comment Share on other sites More sharing options...
ehsnils Posted June 4, 2011 Share Posted June 4, 2011 Get a cheap one at Autozone or so. You can get a decent digital one for $30. It may be that you created a short when you were soldering. Link to comment Share on other sites More sharing options...
Lucas Posted June 6, 2011 Author Share Posted June 6, 2011 no soldering I used the crimp things where you put the two wires in and pinch them shut Link to comment Share on other sites More sharing options...
