Nexmo.co Posted June 3, 2011 Share Posted June 3, 2011 So on my way to work, I was traveling at about 65 on the highway. decided to pass the guy infront of me, decided to not downshift. all is going well till im paralell with the guy, i decide to put my foot into it a little more, *Revv* but wait... hes still right next to me.. :/ the diff noises have been there since i purchased the vehicle. Under any kind of coasting not very speed dependent there's a whine/whir/buzz/*dzzzzzzzzzzz* Noise from the rear. any amount of acceleration puts a temporary stop to the noise. when this clutch goes out I'm very tempted to do the 6speed swap. I've been pricing things out but i dont have much savings, but i'm not going to spend 2grand redoing this stock 5mt setup when i can get the 6 for 3-4. If my motorcycle sell then I'll do it right then. but if it doesn't then i guess i'll have to pull a loan either way for the repair -__- being young and stupid. Just kinda a rant I guess. 84330 on the clock right now, previous owner said clutch was replaced at a subaru dealership in texas when he purchased it at 61k. I've put 2k on it. Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 3, 2011 Share Posted June 3, 2011 The diff is in the back, the clutch is at the engine, two different things and it sounds like two different problems. The whine sounds like a diff problem, the rev's without moving forward on the highway sounds like a clutch slip. Link to comment Share on other sites More sharing options...
whitetiger Posted June 3, 2011 Share Posted June 3, 2011 we have 3 diffs, 2 of which are in the trans(front and center diffs). 1 of the 2 (the front diff) is right behind the clutch. if the front or rear diff goes, the center will not be able to transfer power well to the other, even in "lock or hump" mode. it will feel like a slipping clutch buts its not. now the diff has to shred its internal gears in order to do this. ive blown my rear diff(Launching hard during autox) twice and i know that a blown rear or front diff would make the car seem like a slipping clutch. Ive also broken a rear axle and a similar situation occured. was able to drive home for all scenarios though. Link to comment Share on other sites More sharing options...
Nexmo.co Posted June 3, 2011 Author Share Posted June 3, 2011 The diff is in the back, the clutch is at the engine, two different things and it sounds like two different problems. The whine sounds like a diff problem, the rev's without moving forward on the highway sounds like a clutch slip. Pretty sure that's what i said. Don't know if part of my post made it seem like i didn't know that I had 2 different problems and that i don't know the layout of the car. XD. But thank you for contributing. ive blown my rear diff(Launching hard during autox) twice and i know that a blown rear or front diff would make the car seem like a slipping clutch. Ive also broken a rear axle and a similar situation occured. was able to drive home for all scenarios though. +1 Good to know that a blown diff would feel similar, I've ben through a few clutches in trucks and offroading cars. I haven't ever lost a rear axle or diff before. I've dropped a drive shaft in a truck but it was in 4wd at the time. and i've lost front axles out of the same truck but no symptoms of that felt like clutch. Link to comment Share on other sites More sharing options...
whitetiger Posted June 3, 2011 Share Posted June 3, 2011 remember, when i say blown, i mean a shredded ring/pinion or spider gears. a loss of VLSD pack would not cause this issue. drain the diff and trans oil to check for metal. Link to comment Share on other sites More sharing options...
Nexmo.co Posted June 3, 2011 Author Share Posted June 3, 2011 Yeah I understand. Its definitely not that far gone but I'm sure there will be no surprise when i pull shavings out of there. Link to comment Share on other sites More sharing options...
whitetiger Posted June 3, 2011 Share Posted June 3, 2011 it has to be that far gone. far enough that i causes 1 side of the center diffs output to freewheel, as if there was no diff there at all, or like both rear wheels are off the ground. Link to comment Share on other sites More sharing options...
Nexmo.co Posted June 3, 2011 Author Share Posted June 3, 2011 it only slipped the once so far, I'm sure it would be a continuous problem if i had shredded the a diff wouldn't it? Link to comment Share on other sites More sharing options...
whitetiger Posted June 3, 2011 Share Posted June 3, 2011 yes it would. if it only happened once and is not continually happening, its not a diff. Link to comment Share on other sites More sharing options...
