mikystyle Posted June 1, 2011 Share Posted June 1, 2011 Looking at getting a set of wheels on craigslist. They are Konig "Unknowns" measuring 19x8 with a 45 offset. tires are 235/35/19 nankangs. Will I have any rubbing issues with stock suspension on 09 Sedan? thanks. Link to comment Share on other sites More sharing options...
W1CKED Posted June 1, 2011 Share Posted June 1, 2011 Should...ACCORDING TO THIS STICKY...but if you go lower...they might not. Link to comment Share on other sites More sharing options...
mikystyle Posted June 1, 2011 Author Share Posted June 1, 2011 Correction: 19x9.5 sorry Link to comment Share on other sites More sharing options...
W1CKED Posted June 2, 2011 Share Posted June 2, 2011 So it's 19x9.5, +45?? I seriously doubt that'll work. Most, if not all, of the 9.5" wide wheels I've seen on the forum are in the 30s for offset. My 8.5" wheels are +44...and yer looking at an inch wider, with 1mm difference in offset. Ask Drift Motion or XenonK. Both of those members are who I would talk to about wheel fitment, if I had a question. Link to comment Share on other sites More sharing options...
mikystyle Posted June 2, 2011 Author Share Posted June 2, 2011 So it's 19x9.5, +45?? I seriously doubt that'll work. Most, if not all, of the 9.5" wide wheels I've seen on the forum are in the 30s for offset. My 8.5" wheels are +44...and yer looking at an inch wider, with 1mm difference in offset. Ask Drift Motion or XenonK. Both of those members are who I would talk to about wheel fitment, if I had a question. Thanks a lot for your help Link to comment Share on other sites More sharing options...
W1CKED Posted June 2, 2011 Share Posted June 2, 2011 No worries...much rather help answering a question than have you spend the money to realize it don't work. Link to comment Share on other sites More sharing options...
Drift Motion Posted June 2, 2011 Share Posted June 2, 2011 9.5 +45 and stock suspension isn't a good combination Link to comment Share on other sites More sharing options...
lil_z_33 Posted June 3, 2011 Share Posted June 3, 2011 i ran 19x8 +49 with tein s-techs which is a 2" drop, minor rubbing on fender liner...now I run 19x8 +49 with a 15mm spacer with RCE coilovers and 0 zero rubbing, but im pulled and rolled...tires are 235/35/19...the sizing you want to run is a bad idea... Link to comment Share on other sites More sharing options...
mikystyle Posted June 3, 2011 Author Share Posted June 3, 2011 Thanks guys. Ill probably be sticking with 18s then. I dont wanna have any issues. Plus I'll be saving weight Link to comment Share on other sites More sharing options...
Yayo Posted June 8, 2011 Share Posted June 8, 2011 To piggyback off this, is 235/35R19 a good Size with 19x8 45 offset? I have coliovers and I'm already expecting to roll fenders. Link to comment Share on other sites More sharing options...
turbodog Posted June 14, 2011 Share Posted June 14, 2011 AFAIK, there is no such thing as a 19x9.5 et45 5x100 Konig Unknown. That's actually an exceptionally rare size wheel, if not completely non-existant without going custom. 19x9.5 et40 5x100 is flush rear fitment on some VW's......? Link to comment Share on other sites More sharing options...
Drift Motion Posted June 14, 2011 Share Posted June 14, 2011 To piggyback off this, is 235/35R19 a good Size with 19x8 45 offset? I have coliovers and I'm already expecting to roll fenders. 235/35/19 is very tall tire compare to the OEM size you might rub if you are very low I am going to run 8.5 +45 on 225/35/19, and it's gonna be sunk Link to comment Share on other sites More sharing options...
SpecBGuy Posted June 14, 2011 Share Posted June 14, 2011 235/35/19 is very tall tire compare to the OEM size you might rub if you are very low I am going to run 8.5 +45 on 225/35/19, and it's gonna be sunk how much longer til you put it on? Link to comment Share on other sites More sharing options...
Drift Motion Posted June 14, 2011 Share Posted June 14, 2011 how much longer til you put it on? i've been lagging it on picking up the tires should be this thursday, and mount it the same day and hopefully picture by weekend? Link to comment Share on other sites More sharing options...
