Lookatmyrust Posted May 31, 2011 Share Posted May 31, 2011 Had my rotors red hot today. not a warp in them but are they still safe to use.. they are just your standard rotor from a part store. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted May 31, 2011 Share Posted May 31, 2011 You just did your own heat treatment. Link to comment Share on other sites More sharing options...
Nrw Posted May 31, 2011 Share Posted May 31, 2011 in for pics Link to comment Share on other sites More sharing options...
FPerron Posted May 31, 2011 Share Posted May 31, 2011 Should not be a problem. However, repeated overheating a cooling will eventually cause radial cracks in the rotor surface. Again, nothing to worry about until the cracks can be felt by dragging your fingernail over the rotor surface. You can still use a rotor that has small surface cracks, but you must carefully monitor them to spot any larger cracks that indicate the need to replace the rotor. BTW, how did you manage to get your brakes that hot? Doesn't sound like you track the car, or you'd know the above already. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 31, 2011 Share Posted May 31, 2011 You just did your own heat treatment. No he didnt. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
