Xenonk Posted June 8, 2005 Share Posted June 8, 2005 nope, my brother did that with his WRX and it just works fine. Keefe Keefe Link to comment Share on other sites More sharing options...
NutBucket Posted June 8, 2005 Share Posted June 8, 2005 People are claiming that if you cut those wires the starter kill won't work. Another site a read suggests jumping those two leads for those modules to the acc lead that the TT is hooked into. They claim that it will allow the starter kill to work. Anyway, I was asking more along the lines of if anything of that sort needs to be done for the Legacy. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 8, 2005 Author Share Posted June 8, 2005 i didn't do any of that, I just hooked up the wires. when i "turn off" the car, the steering wheel locks, i get out, and lock the doors with the key fob. The car remains on 'til the end of the countdown and then turns itself off. Link to comment Share on other sites More sharing options...
Xenonk Posted June 8, 2005 Share Posted June 8, 2005 the starter kill is, well for the starter. The only thing that turbo timers to is to keep the current running through the system to keep the car running. Once you start a car, that's the only job that the starter would do. The starter kill is only there to verify if the key itself is in the ignition to continue the circuit to start the car. Old school hot wiring was just there to get a positive voltage on the starter and then connect the ground and main power wires together (hence that silly spark you see in movies). Keefe Keefe Link to comment Share on other sites More sharing options...
NutBucket Posted June 15, 2005 Share Posted June 15, 2005 Thanks for the help guys. Got the timer installed and it works great. I also used a GReddy. I mounted mine in the center console to keep it out of sight. Link to comment Share on other sites More sharing options...
cole46_51 Posted April 24, 2006 Share Posted April 24, 2006 trying to install a turbo timer, but I don't know where the parking brake wire is, much less would know which wire it is even if I was looking @ it:icon_bigg Not sure if it is under the steering column with the ignition wires or actually under the parking brake. So with that said, where is this wire? 2nd, if I have to take trim off around the parking brake, please describe how as I don't want to go pulling and snap something I shouldn't! Thanks! Link to comment Share on other sites More sharing options...
ralphyralph5 Posted April 25, 2006 Author Share Posted April 25, 2006 Well boss, all I can tell you is that I couldn't figure it out so i didn't bother with it. Link to comment Share on other sites More sharing options...
