Kaos22B Posted May 28, 2011 Share Posted May 28, 2011 All the following parts are NEW. I'm clearing out a ton of stuff I don't need anymore. edit:MANY MORE PARTS FOUND NOT IN THE PHOTO BELOW! Oil Fill tube Oil Cap seal 2 sets front timing belt cover seals (1) WRX/STi bov gaskets (2) WRX/STi tmic inlet gaskets (4) Rear Main seals (1) Non-avcs cam gear bolts DB Cable throttle body gasket (4) AVCS Cam seals (1 ) Thermostat gaskets (5) Oil/water cooler seals 2 sets remaining AVCS style valve cover gaskets 1 set remaining, Valve seals (8 intake 8 exhaust) Flywheel bolts SOLD DBW Throttle body gasket SOLD Non avcs cam seals SOLD Oil pump seal SOLD Water pump gasket SOLD Spark plug hole seals 2.0 WRX Valve cover gaskets Group N engine mount. 1 only, slightly used. Power steering fluid reservoir bracket (this is actually used) WRX/STi fuel pump controller (this is used, but as you can imagine it doesn't wear) Quantities updated as of 06/14/11 IF YOU DON'T SEE IT BUT NEED SOMETHING JUST ASK! I have boxes of crap I haven't cataloged or taken photos of. Wiring (TONS! from various swaps I've done over the years), clips, bolts, yada yada Pick your part(s) and I'll give you a quote. Obviously bulk gets a discount. See my other soon to be posted thread for stainless braided an lines and fittings. http://legacygt.com/forums/attachment.php?attachmentid=100642&d=1306562747 Link to comment Share on other sites More sharing options...
