dfsubiegt Posted May 24, 2011 Share Posted May 24, 2011 Guys please help cause i cant figure this out for the life of me. I just put a fmic on my car and when i get into boost im hearing this crazy noise. It sounds like a high pitch air leak almost. I checked all the clamps and my bov flange and i cant find where its coming from at all. Its clear as day from inside the car. Its a forge bov with the different color springs. Im using the yellow spring supposably its good for 15 to 22 lbs and im just under 18. you think maybe this noise is coming from leak through that idk some suggestions ?? Link to comment Share on other sites More sharing options...
MrHellrais3R Posted May 24, 2011 Share Posted May 24, 2011 maybe its compressor surge. Try a softer spring. With most FMIC, you want a softer spring rate, or just get a ssqv and call it a day. Link to comment Share on other sites More sharing options...
dfsubiegt Posted May 24, 2011 Author Share Posted May 24, 2011 yeah im gonna try the different springs tomorrow and see what happens thanks Link to comment Share on other sites More sharing options...
Brosephine Posted May 25, 2011 Share Posted May 25, 2011 I'm at 18psi and the tuner said stick with blue. food for thought. get a boost leak test done for the source of the leak. tighten the F outta the recirc hose at the bpv. EDIT: perhaps I'M using the wrong spring, lol. just do a boost leak test it makes it easy to find a system leak. EDIT: At 18psi, I'm holding boost perfect with the blue spring according to my log Link to comment Share on other sites More sharing options...
dfsubiegt Posted May 25, 2011 Author Share Posted May 25, 2011 thanks man will do Link to comment Share on other sites More sharing options...
dfsubiegt Posted May 25, 2011 Author Share Posted May 25, 2011 Switched the spring rechecked all the clamps on the piping and nothing changed still hearing this noise it sounds like an air leak I have no idea Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 25, 2011 Share Posted May 25, 2011 If it sounds like an air-leak, then it probably is. Just because the clamps are tight, doesn't mean there isn't a leak. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
m sprank Posted May 25, 2011 Share Posted May 25, 2011 Get an intake leak tester. Link to comment Share on other sites More sharing options...
