keithss Posted May 20, 2011 Share Posted May 20, 2011 I just picked up a set of 08 2.5i limited seats to swap into my 08 2.5se. I currently have the cloth seats with power driver,manual passenger, no heat. The seats I bought are the same setup but with heat. I also got the switch for the heated seats for the center console. Am I correct in assuming it should be simple bolt in plug and play and just plug in the seat heater switch in the center console and everything should work? Thanks for all of your input. Just not looking to have any surprises when i go to put them in with wiring or anything. Keith Link to comment Share on other sites More sharing options...
biketowork Posted May 21, 2011 Share Posted May 21, 2011 Keith, I don't have the answer for you, but was also considering swapping out the front seats with heated ones after we move. Could you keep us updated on the project? Hope it is an easy swap. Link to comment Share on other sites More sharing options...
