keithss Posted May 20, 2011 Share Posted May 20, 2011 I just picked up a set of 08 2.5i limited seats to swap into my 08 2.5se. I currently have the cloth seats with power driver,manual passenger, no heat. The seats I bought are the same setup but with heat. I also got the switch for the heated seats for the center console. Am I correct in assuming it should be simple bolt in plug and play and just plug in the seat heater switch in the center console and everything should work? Thanks for all of your input. Just not looking to have any surprises when i go to put them in with wiring or anything. Keith Link to comment Share on other sites More sharing options...
keithss Posted May 24, 2011 Author Share Posted May 24, 2011 Well, I installed the seats this weekend and they was no wiring for the heated seats in the car. Does anyone know If there is a way to buy a harness from subaru and plug the seats into the car and install the factory switch to operate them? Link to comment Share on other sites More sharing options...
Code Posted May 24, 2011 Share Posted May 24, 2011 Vacation pics "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
keithss Posted May 24, 2011 Author Share Posted May 24, 2011 forgive my noobness but vaction pics? are you talking about this link http://www.newreason.com/vacationpix/ The site is no longer working Link to comment Share on other sites More sharing options...
Code Posted May 24, 2011 Share Posted May 24, 2011 nope, this link http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html?t=6216&highlight=%22vacation+pics%22 "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
golunnova Posted June 22, 2011 Share Posted June 22, 2011 How did you connect the wiring for the power seats on the passenger side for your new seats? Was the wiring already there for the 08 2.5SE? And did you get the heat working by any chance? Cheers! Link to comment Share on other sites More sharing options...
mk6933 Posted June 22, 2011 Share Posted June 22, 2011 08 2.5i Limited don't have power seats on the passenger side. Only 09 2.5i Limited have power passenger seat. Link to comment Share on other sites More sharing options...
golunnova Posted June 22, 2011 Share Posted June 22, 2011 Oh good point mk6933. So if the the 2009 2.5i limited has power passenger seats, do you believe the 2009 2.5i SE already has wiring buried somewhere for the power passenger seats? Link to comment Share on other sites More sharing options...
ktm200 Posted June 22, 2011 Share Posted June 22, 2011 No dice on the buried wiring, different wiring harness entirely for the 2.5i vs the limited cars. And by wiring harness I mean the entire car, so you wouldn't be able to simply unplug a portion of the harness you need, its all spliced together. Youd have to find a wrecked limited and start cutting out the required sections. Link to comment Share on other sites More sharing options...
golunnova Posted June 22, 2011 Share Posted June 22, 2011 I'm hoping your comment about the different wiring harness for the 2.5i vs the limited cars is only for the passenger side seat and not for the driver side seat as well... Link to comment Share on other sites More sharing options...
keithss Posted June 23, 2011 Author Share Posted June 23, 2011 Ya drivers power is no problem but the passenger side doesnt have any extra harness'. Im still trying to get the heated part to work. I got a local junkyard yanking out the sections of wire I need from a wrecked limited for me so I can try to hook it up. Link to comment Share on other sites More sharing options...
