LegacyDan Posted May 20, 2011 Share Posted May 20, 2011 Do the 05-09 Legacys have a 3 port boost solenoid as standard? i thought it was a 2 port but after having a closer look today there is 3 lines coming of it and 2 electrical connections so im guessing its a 3 port Link to comment Share on other sites More sharing options...
jmatijas_gt Posted May 20, 2011 Share Posted May 20, 2011 USDM's do not Link to comment Share on other sites More sharing options...
NSFW Posted May 23, 2011 Share Posted May 23, 2011 What do each of those 3 lines connect to? It's possible that JDM cars had 3-port solenoids, but it's also possible that you're looking at something that isn't the solenoid. Link to comment Share on other sites More sharing options...
LegacyDan Posted May 23, 2011 Author Share Posted May 23, 2011 i thought it was the solenoid here's a picture of it: http://i32.photobucket.com/albums/d3/desperatedano/IMG_20110512_112017.jpg from what i can see it 2 of the pipes go to the turbo inlet pipe, not sure about the other one Link to comment Share on other sites More sharing options...
TRSCobra Posted May 23, 2011 Share Posted May 23, 2011 The one with the blue electrical connector on it is the bcs and it looks to be the same 2-port that is on USDM LGTs. Link to comment Share on other sites More sharing options...
LegacyDan Posted May 23, 2011 Author Share Posted May 23, 2011 whats the thing beside it with the black electrical connector? Link to comment Share on other sites More sharing options...
TRSCobra Posted May 23, 2011 Share Posted May 23, 2011 Pretty sure that's the MAP sensor. Link to comment Share on other sites More sharing options...
SonicSpecB Posted May 23, 2011 Share Posted May 23, 2011 ^^^correct on both... Link to comment Share on other sites More sharing options...
m sprank Posted May 25, 2011 Share Posted May 25, 2011 Let is BCS. Right is MAP sensor. Fuzzy guy is filter. Link to comment Share on other sites More sharing options...
black318i Posted June 6, 2011 Share Posted June 6, 2011 I thought the MAP sensor was on the TB? Are there two MAP sensors? Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 6, 2011 Share Posted June 6, 2011 I thought the MAP sensor was on the TB? Are there two MAP sensors? that throttle body looks nothing like mine Link to comment Share on other sites More sharing options...
black318i Posted June 6, 2011 Share Posted June 6, 2011 That pic came from the 2005 repair manual. Link to comment Share on other sites More sharing options...
m sprank Posted June 7, 2011 Share Posted June 7, 2011 That is an STi. Not a Legacy. LOL. Link to comment Share on other sites More sharing options...
black318i Posted June 7, 2011 Share Posted June 7, 2011 Hmm not sure why it's in the BL*****, BP***** from 2005MY manual then. I looked it up last night because I read it's a good idea zip tie the vac line to the MAP sensor. When I looked at the pic my first thought was that something isn't right because there is no vac line in the pic. Link to comment Share on other sites More sharing options...
NSFW Posted June 7, 2011 Share Posted June 7, 2011 The NA intake manifolds look about like that as well. Link to comment Share on other sites More sharing options...
m sprank Posted June 7, 2011 Share Posted June 7, 2011 Ah, NA car it is. Yes, when reading the manual make sure you are in the proper section, LOL. Link to comment Share on other sites More sharing options...
black318i Posted June 7, 2011 Share Posted June 7, 2011 Good point I didn't even think of that . All the pics show the same thing so I guess there is a flaw with the manual. Link to comment Share on other sites More sharing options...
m sprank Posted June 7, 2011 Share Posted June 7, 2011 Not the first. I have all years and sometimes check between them to see if there were "updates". Link to comment Share on other sites More sharing options...
TheBoostNazi Posted June 7, 2011 Share Posted June 7, 2011 Open up your hood, immediately you will find a manifold and throttle body that has zero resemblance of the pic you posted. anyway, the ecu uses a map sensor on the left strut/airbox well for wrx/sti's and the LGT uses one to the right of the inlet bend at the hex screw. Link to comment Share on other sites More sharing options...
