2006 SpecB Posted May 12, 2011 Share Posted May 12, 2011 I just installed my SPT CBE on my 2006 Spec B and noticed the left muffler is hanging higher than the right. I think the stock did the same, but not as bad. Any easy ways to even this out? They seem to fit fine left to right inside the muffler cutouts, not perfect, but fine. Any thoughts there are appreciated as well. Thanks Link to comment Share on other sites More sharing options...
lgtftw Posted May 12, 2011 Share Posted May 12, 2011 Check your hangers again. Link to comment Share on other sites More sharing options...
2006 SpecB Posted May 12, 2011 Author Share Posted May 12, 2011 I checked hangers and they seem to not want to budge at all from their position. It looks like one of them could use an adjustment but when I try to move it, it is not going anywhere. Almost as if one of the hangers needs to be longer....not sure why this is? Link to comment Share on other sites More sharing options...
AdAstra Posted May 12, 2011 Share Posted May 12, 2011 Try to use a hose clamp on the side that is hanging too low...basically just slide the clamp around the rubber hanger and tighten it up until it pulls the exhaust up into the correct position. Link to comment Share on other sites More sharing options...
lgtftw Posted May 12, 2011 Share Posted May 12, 2011 People may not agree with this but I put some lubricant on the rubber hanger and it moves a lot better. Also, try moving the exhaust left to right a little bit, they might settle even. Link to comment Share on other sites More sharing options...
2006 SpecB Posted May 12, 2011 Author Share Posted May 12, 2011 Thanks for the reply, I meant to say the side is hanging too high not too low. I need to get it to drop down about a third of an inch. Link to comment Share on other sites More sharing options...
iNVAR Posted May 12, 2011 Share Posted May 12, 2011 You need to loosen up the 3 connections for your CBE. The one at the donut gasket where it meets the DP. And the two mufflers where it connects to the Y-pipe. Then you have to adjust things, and possibly have an assistant hold it in place, while you tighten it back up. A degree or two at the DP->CBE joint can translate into an inch or two or three of difference at the exhaust tips. Link to comment Share on other sites More sharing options...
2006 SpecB Posted May 12, 2011 Author Share Posted May 12, 2011 Thanks iNVAR! I will give that a shot...... Link to comment Share on other sites More sharing options...
iNVAR Posted May 13, 2011 Share Posted May 13, 2011 Hopefully that works. That's how I did it with my own SPT. Link to comment Share on other sites More sharing options...
SpecBGuy Posted May 13, 2011 Share Posted May 13, 2011 my passenger side hangs lower on my spt. i tried the clamp or other stuff to tighten the rubber hanger but doesnt help. i also got shorter hangers and doesnt help. Link to comment Share on other sites More sharing options...
