specialB Posted May 10, 2011 Share Posted May 10, 2011 My dongle connecting the AP to the port under the dash does not like to keep a snug fit and it tends to reset itself over minor bumps when I'm trying to use the device. Anybody else have this problem/have a cure for it coming loose? Link to comment Share on other sites More sharing options...
nightspeed98 Posted May 11, 2011 Share Posted May 11, 2011 Same issue Link to comment Share on other sites More sharing options...
fishbone Posted May 11, 2011 Share Posted May 11, 2011 Not snug? Try to wrap electrical tape around the OBD connector in the car, it should eliminate the slack and make for a snug fit. Link to comment Share on other sites More sharing options...
nightspeed98 Posted May 11, 2011 Share Posted May 11, 2011 big feet. i think i touched it while depressing clutch a few times too many. its too big. i am considering relocating the whole thing sideways or something. be nice if cobb had a new one that's smaller or even a 90 degree adapter for it. maybe one that leaves port still open... Link to comment Share on other sites More sharing options...
specialB Posted May 11, 2011 Author Share Posted May 11, 2011 The electrical tape solution might be effective, I'll give it a try. Link to comment Share on other sites More sharing options...
fishbone Posted May 12, 2011 Share Posted May 12, 2011 If you keep bumping it I would definitely relocate it. I have not looked close enough but I think I remember seeing the OBD2 plug as removable from the mounting point, so potentially you could unbolt it, hook up the dongle and zip-tie it somehow/somewhere out of the way under the dash. Have a look. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 13, 2011 Share Posted May 13, 2011 The OBD2 port is held in by 2 screws(if I remember right). It has enough slack so that you can relocate it to the fuse area above it. From there, you can probably come up with some sort of device(*cough*zipties?) to secure it. Link to comment Share on other sites More sharing options...
CDubbs Posted May 16, 2011 Share Posted May 16, 2011 Thanks for the thread folks. I will do the same. Methinks I am going to fish the cable up and get a spare defrost vent to rig up an AP mount. No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
