JimJamie Posted April 23, 2011 Share Posted April 23, 2011 The low and high beam lights work, but the dashboard headlight indicator does not turn on when I turn the lights on fully. I know in some cases unusual activity by certain dashboard lights indicate a problem. Is that what is happening here? I noticed this right after I had front end work done at the local Subaru dealer. "Front lower bushings" at $211, and "Sway bar in links" at $189. Any connection to the dashboard light problem? Link to comment Share on other sites More sharing options...
ehsnils Posted April 23, 2011 Share Posted April 23, 2011 Look and see if you find connector "i1" as from pic below: http://www.bedug.com/pics/headlight_wiring.PNG And see if there is a loose wire for pin 27 or 7. The headlight is presented by a blue LED, and I doubt that it's the LED that's gone but it does happen sometimes and if that's the case you may need a new instrument cluster or find someone skilled at soldering. But you need to find the "i1" or possibly the "i11" connector and that's probably under the dashboard. The "i11" is on the instrument cluster or close to it. Link to comment Share on other sites More sharing options...
JimJamie Posted April 24, 2011 Author Share Posted April 24, 2011 On my '06 Subaru Outback LL Bean sedan, the high beam is represented by a blue dashboard light on the upper right side, which still works. The headlights are represented by a white/green light on the lower left side. The headlights work but the dashboard light does not. Moving the left hand stalk one click turns on a light on the upper right, above what will be the blue high beam when I push the stalk forward after having moved the stalk two clicks. Link to comment Share on other sites More sharing options...
ehsnils Posted April 24, 2011 Share Posted April 24, 2011 (edited) Ah - I misunderstood you, thought it was the high beam indicator. So it's the green indicator that indicates position lights that doesn't work. Check fuse #14 and #16 in the fuse box in the driving compartment. And check the parking light switch on the steering wheel column too. Even if I doubt that it's the problem in this case. If fuse #16 is dead then you will get a lot of other instrument panel illumination missing too, and if everything else works it should only be the indicator that's out. Edited April 24, 2011 by ehsnils Link to comment Share on other sites More sharing options...
The Chief Posted September 8, 2016 Share Posted September 8, 2016 I actually have this problem with the blue high-beam indicator not coming on in the instrument cluster. It looks like this isn't a fuse problem, but wiring, correct? Where do I find the wiring in the diagram? My '09 SE has the DRLs deactivated (I pulled the plug on my '06), but I'm not sure if something else had been disconnected before I got the car. Link to comment Share on other sites More sharing options...
mzsinko84 Posted September 25, 2021 Share Posted September 25, 2021 I have an 05 LGT, the DTRL’s module was already removed before I bought the car which in my opinion is a good thing. I noticed the other day that my headlights on light in the dashboard wasn’t coming on, I also noticed yesterday that whether I’m in park, reverse, neutral or drive, non of the gear lights where lighting up. Link to comment Share on other sites More sharing options...
mzsinko84 Posted September 25, 2021 Share Posted September 25, 2021 I checked to make sure my high beams, low beams, turn signals and my reverse lights are working and they are all working, the headlights on indicator isn’t working. Link to comment Share on other sites More sharing options...
Marvick08GT Posted September 25, 2021 Share Posted September 25, 2021 Either the bulb is blown or someone disconnected the daytime running lights relay. Under the drivers kick panel, that relay also controls the high beam indicator. I have HIDs, so I have mine unplugged, this is a side effect. Good luck! Link to comment Share on other sites More sharing options...
