joe sko Posted April 11, 2011 Share Posted April 11, 2011 I replaced my drivers front hub assembly just to find out after my test drive that the bad wheel bearing I had was on the passenger side. So I ordered another hub assembly for the passenger side and installed it. This side came off much easier (being the second time i did it in 3 days) but after installing it the steering is messed up. I have the dead zone in the middle of the steering some have on here but it is accompanied by a shudder and suspension/steering rattle. When going over some bumps it rattles and some it doesnt. It only shudders when initiaing a turn, when you are in the turn its smooth. I have gone over the entire front end checking obvious components like tie rod ends, ball joints etc. It wasn't like this before the wheel bearings were done. I dont see how i could have messed anything up because nothing was ceased and all you remove is basically the brakes. This sh*ts weak please help. Link to comment Share on other sites More sharing options...
joe sko Posted April 11, 2011 Author Share Posted April 11, 2011 "tighten your axel nut to spec dumba**" ha Link to comment Share on other sites More sharing options...
