ploblem after front wheel bearing replacement
joe sko
I replaced my drivers front hub assembly just to find out after my test drive that the bad wheel bearing I had was on the passenger side. :mad: So I ordered another hub assembly for the passenger side and installed it. This side came off much easier (being the second time i did it in 3 days) but after installing it the steering is messed up. I have the dead zone in the middle of the steering some have on here but it is accompanied by a shudder and suspension/steering rattle. When going over some bumps it rattles and some it doesnt. It only shudders when initiaing a turn, when you are in the turn its smooth. I have gone over the entire front end checking obvious components like tie rod ends, ball joints etc. It wasn't like this before the wheel bearings were done. I dont see how i could have messed anything up because nothing was ceased and all you remove is basically the brakes. This sh*ts weak please help.
