scott6058 Posted April 5, 2011 Share Posted April 5, 2011 New to this forum but I have a code 35 which leads me to believe this may be the problem. What does anyone else know. Intermitent misfire while driving like running on two cylinders lousy idle also. Where is this canister purge valve located? Thanks for any help. best regards Scott Link to comment Share on other sites More sharing options...
subikid90 Posted April 5, 2011 Share Posted April 5, 2011 It is either on your passenger side strut tower or under the intake manifold on the passenger side. I can't remember which on it is for sure, I am leaning towards the on under the intake manifold. It will have a 2 vacuum lines, and one will go to the purge canister. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
scott6058 Posted April 5, 2011 Author Share Posted April 5, 2011 Thanks Subikid90 Does any one know if the canister purge valve is very problematic or is it unusual that they go bad:rolleyes: Link to comment Share on other sites More sharing options...
sqc151 Posted April 20, 2011 Share Posted April 20, 2011 its a common problem. google the part location and it will pin point it for you. also, since its under the intake manifold on the passenger side. remount it on top of the manifold with the screw that holds the wire holder. this will make it easier to replace again. make sure you remember which vacuum line goes where. Link to comment Share on other sites More sharing options...
