scoobydoobie Posted April 4, 2011 Share Posted April 4, 2011 What is the widest wheel/tire set up people run on Bilsteins/Pinks? Without rubbing either the strut perch or the fender? I currently have 17 x 7.5 wheels with 225/45s and am looking to run a wider wheel and a wider tire. Either 17" or 18" wheels. Link to comment Share on other sites More sharing options...
BigBlack-V Posted April 4, 2011 Share Posted April 4, 2011 there are several threads regarding this topic but I will give you my .02 cents. i have 04 STI BBS wheels on my spec.B 225/45/17 tire on 17x7.5 rims and you may be able to get 235/45/17's on that rim you have. I had 18x8 rims on my spec.B lowered on Cobbs and I rubbed using a 245/40/18 with a negative camber and rolled wheel wells. I ended up selling those 18's. I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 4, 2011 Author Share Posted April 4, 2011 links to the other threads about this? Looked but did not see them. IMO a 235/45/17 is too much tire for a 17x7.5. Do you think the 18 x 8s would have rubbed if you had had 245/35/18's instead? thanks for the feedback. Link to comment Share on other sites More sharing options...
BigBlack-V Posted April 4, 2011 Share Posted April 4, 2011 ^ I am sorry I can not answer that I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
wpmarky Posted April 4, 2011 Share Posted April 4, 2011 I had 235/40/18 Toyo's on 18x8 +48 and -1 camber all around, didn't rub while on bilsteins/pinks. 245/35/18 might fit with a fender roll. Depends what offset wheels you get, and depends if your tires run wide or skinny. +35 offset will rub with 245/40/18's. Try to get +48 Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 4, 2011 Share Posted April 4, 2011 I'm going to shoot for a 245/50/17 or a 245/45/18 as my next tire on an 8" rim with a +44ish offset. My 225/55/17's fit with plenty of room to spare. In the rear, if I ran less camber, and rolled the fenders, I could easily fit a 245. The front is a little trickier, but I don't think it would be impossible. My fenders are Outback, but I am still on Bilsteins. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 6, 2011 Author Share Posted April 6, 2011 Well if I buy new, I think I found the 18's I would want. They are 18x8 +48mm offset Sparco wheels (http://www.tirerack.com/wheels/results.jsp?filterSize=18&filterFinish=All&filterBrand=Sparco&filterWeight=All&autoMake=Subaru&autoModel=Legacy+Sedan+2.5+GT&autoYear=2005&autoModClar=Base+Model&sort=Brand&filterNew=All&filterSpecial=false). Do you think I'd be better off with 235/40/18 or 245/35/18 or 245/40/18? Pretty sure from reading replies here that a 245/40 would rub. I want a wider contact patch than I have now, and am thinking that going from 225s->235s is not significantly wider, which is why I am pretty much set on 245s. Link to comment Share on other sites More sharing options...
05gtlimited300 Posted April 13, 2011 Share Posted April 13, 2011 When i had my pinks on stock struts, my Rotas (18x8 P1) rubbed with 235/40/18 but mostly on bumps Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 13, 2011 Share Posted April 13, 2011 It's a terrible balancing act between tire choice, wheel width, and wheel offset. I think an 18x8 to 18x8.5 with a +45 (for the 8") to +40 (for the 8.5) offset will probably put you in a good place to fit something like a 245. You might need to do some fender magic, but you live close enough to some great fender rolling shops, that it isn't really an issue. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 13, 2011 Author Share Posted April 13, 2011 Thinking now about a 17 x 8.5 and running 245/40s. Thanks for the feedback from everyone. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 13, 2011 Share Posted April 13, 2011 That should fit pretty well. You could even fit that size tire on a 17x8. 05+ STi guys often go for that size on the stock wheels. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
scoobydoobie Posted September 26, 2011 Author Share Posted September 26, 2011 Another wheel choice...18x8.5 +48. With 245/35/18 fit w/Bilsteins/Pinks? Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 26, 2011 Share Posted September 26, 2011 Probably not. SublimeJoe was able to fit an 18x8.5 +39 with a 245/45/18 with only a little room to spare on stock struts. I think you'll hit with +48. You will definitely need to do some fender magic to clear the tires. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
scoobydoobie Posted September 26, 2011 Author Share Posted September 26, 2011 Ok thanks. I don't mind some fender work if need be. Strut side is more of a concern as I don't want to change suspension. You know how nice the HD/Pink combo is SublimeJoe's 245/45/18 is still a good bit larger than my planned 245/35/18 though no? Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 26, 2011 Share Posted September 26, 2011 Taller. But his wheels are 9mm further away from the strut than your proposed setup. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
scoobydoobie Posted September 26, 2011 Author Share Posted September 26, 2011 Taller. But his wheels are 9mm further away from the strut than your proposed setup. Gotcha. Wasn't sure how tires being taller or not would effect clearance. So in that case I might look into even a 245/40 for some added protection for the wheels. But I don't know, that might really be pushing it. Link to comment Share on other sites More sharing options...
suds2250 Posted October 9, 2011 Share Posted October 9, 2011 I run 245/35/18's on Rota 18x8 +48 offset. JDM bilstiens and Prova springs, no rubbing at all. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 10, 2011 Author Share Posted October 10, 2011 That's great to hear. You have any pics of your set up? Link to comment Share on other sites More sharing options...
suds2250 Posted October 11, 2011 Share Posted October 11, 2011 http://legacygt.com/forums/vbpicgallery.php?do=view&g=1079 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
mattg Posted October 11, 2011 Share Posted October 11, 2011 IMO a 235/45/17 is too much tire for a 17x7.5. That's what I run and they fit perfectly. Link to comment Share on other sites More sharing options...
