TrueWhiteBoy Posted April 4, 2011 Share Posted April 4, 2011 They were a couple months apart. I finally got around to picking up a set of bulbs to change the one, only to find that neither are working. Reverse and the running lights work fine. The center brake light works fine Any chance someone might have an idea what's causing it? Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted April 5, 2011 Author Share Posted April 5, 2011 bump Link to comment Share on other sites More sharing options...
ssbtech Posted April 5, 2011 Share Posted April 5, 2011 Wagon? Sedan? Either way, looking at the wiring diagram the high-mount stop lamp is wired in parallel with the other two brake lights, so power is getting to the lights and the switch is working fine. I don't remember the base of the bulb, is it possible that you haven't twisted the bulb in far enough? Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted April 5, 2011 Author Share Posted April 5, 2011 2005 Sedan I think it's one that you clip in, but I can certainly try it again. Much appreciated! I'll try it out later today and post the results. Link to comment Share on other sites More sharing options...
PhilT Posted April 5, 2011 Share Posted April 5, 2011 The electrons are probably leaking out from somewhere they shouldn't be. Have you thought about a grounding kit ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
GTS Jeff Posted April 6, 2011 Share Posted April 6, 2011 How many forum members does it take to change a light bulb? Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted April 6, 2011 Author Share Posted April 6, 2011 How many forum members does it take to change a light bulb? Depends...do they have to change it properly? I still don't know if that's the problem, I got stuck at work and ran out of light. I honestly hope it is though. Link to comment Share on other sites More sharing options...
