wagdaddy Posted April 1, 2011 Share Posted April 1, 2011 so i found out the only automatic tranny that will fit my 95 legacy is a 95 or early 96 what i am wondering is if a new engine say 98 - 00 engine and tranny will mount up in the car ive found a few or if the mounting is different any help ? Link to comment Share on other sites More sharing options...
johnegg Posted April 1, 2011 Share Posted April 1, 2011 you are limited by the 00 model change. (99 for ej22s engines, 99 for the outback auto trans and probably 99 for the legacy auto trans but i'm not sure.) so if you limit your self to 95 - 98 you can use any auto trans with a matching 4.11 final drive ratio. this means you can use any auto trans 95 - 98 from a car with a 2.2L engine or a 1.8L engine. (except 95 impreza it has a speedo cable not a speed sensor.) hope this helps. Link to comment Share on other sites More sharing options...
