LzyKid4Life Posted May 23, 2005 Share Posted May 23, 2005 Does any one's radiator fan seem louder then normal...after a while?? and does the intake silencer removal make the fan louder... dont remeber if i had this "problem" when i had it out last time....only one fan runs, dont know if thats the problem... hoping you guys have an answer or a conlusion to this "problem" of mine... oh and I took off my bumper to clear the headlights... so dont know if i could have unplugged something??? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 23, 2005 Share Posted May 23, 2005 one fan should run when the engine is running. The second fan only runs when the AC compressor is on, or the car is starting to overheat. intake silencer has nothing to do with fans. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Throttlejockey Posted May 23, 2005 Share Posted May 23, 2005 Turn off the AC before you start the car in the morning and see if the fan shuts off. If it doesn't you have the dreaded cooling fan problem. Here's the post about cooling fan troubles. http://legacygt.com/forums/showthread.php?t=10568 Link to comment Share on other sites More sharing options...
LzyKid4Life Posted May 24, 2005 Author Share Posted May 24, 2005 well which side is the cooling fan left or right?, that would be looking at your car... and if it is this "cooling fan" problem gotta get it serviced? sorry if its a dumb question just wanna make sure... Link to comment Share on other sites More sharing options...
Kaptan Posted May 24, 2005 Share Posted May 24, 2005 You, my friend have been hit by the cooling fan fairy:eek: Looks like you will need to make an appt with your local dealer to have your ECU replaced:D Good Luck! Link to comment Share on other sites More sharing options...
Tide Posted May 24, 2005 Share Posted May 24, 2005 moved thread to tech forums. Link to comment Share on other sites More sharing options...
LzyKid4Life Posted May 25, 2005 Author Share Posted May 25, 2005 thanks everybody for the help, should have searched first, just didnt think any one else had this problem.... Link to comment Share on other sites More sharing options...
