boostedgrocerygetter Posted March 24, 2011 Share Posted March 24, 2011 im looking at getting a down pipe and was wondering what would be better a perrin or invidia. Link to comment Share on other sites More sharing options...
GTStage2 Posted March 24, 2011 Share Posted March 24, 2011 I hear perrin has fitting issues. I just ordered a catless invidia dp. Ill let you know how I feel about it after install. Link to comment Share on other sites More sharing options...
executor485 Posted March 24, 2011 Share Posted March 24, 2011 I've got an invidia and I like it. However, I will warn you that it's a PITA to install/remove because the bottom 2 bolts require you to use an open ended wrench to tighten/loosen the bolts. The way it's made (maybe just version 2) the bolts are so close that you cant get a socket on the bolt But, if you're not planning on removing it ever... It's a good pipe. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
GTStage2 Posted March 24, 2011 Share Posted March 24, 2011 Thank you for the warning! I'm hoping that has changed from your pipe to mine cause I hate stuff like that!! Engineers paid the big bucks to annoy us who actually work on things!! Link to comment Share on other sites More sharing options...
Windy Road Posted March 24, 2011 Share Posted March 24, 2011 I'm running the Perrin one piece down pipe. The bolts to the turbo are a little tight to get to but that's with all aftermarket down pipes really. Only then that it's a good piece. My buddy said it's made from a high quality stainless steel when he welded in my wideband bung. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
GTTuner Posted March 24, 2011 Share Posted March 24, 2011 Perrin, ughhhh. Fitment is terrible, it comes within a quarter inch of the firewall and the outlet is too high, usually requiring to remove the center tunnel heat shield. I've installed both, Invidia all the way. Just need to ck the WG flapper clearance before you bolt it up. Link to comment Share on other sites More sharing options...
GTStage2 Posted March 24, 2011 Share Posted March 24, 2011 Paul. My pipe should be in soon and I'll be installing it, are you talking about the divorced piece and making sure there is enough clearance to the inside of the turbo? Just double checking what you mean by WG flapper clearance!? Link to comment Share on other sites More sharing options...
executor485 Posted March 24, 2011 Share Posted March 24, 2011 the divorced area on the inside (bellmouth area) of the invidia DP had some issues on some versions. It would prevent the internal wastegate flapper from fully opening. It usually required some cutting to be done on the divorce section. Mine didnt have that issue and I havent heard of the new versions having the issue, but its a thought that is carried through with every person that purchases an Invidia DP. Not that its bad to check, but its not a typical problem anymore. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted March 24, 2011 Author Share Posted March 24, 2011 thank you all for your responses i was strong on the perrin but think im gonna swing to the invidia side. does anyone know where i could get the adaptor to fit it to the stock cbe. Link to comment Share on other sites More sharing options...
GTStage2 Posted March 25, 2011 Share Posted March 25, 2011 Executor485 excellent description. Thank you i'll make sure I check everything before tightening up. Link to comment Share on other sites More sharing options...
executor485 Posted March 25, 2011 Share Posted March 25, 2011 thank you all for your responses i was strong on the perrin but think im gonna swing to the invidia side. does anyone know where i could get the adaptor to fit it to the stock cbe. FBP has the adaptor, or I think I may have mine somewhere still. http://www.fredbeansparts.com/index.php/3-inch-downpipe-to-2-5-inch-cat-back-exhaust-adaptor-1.html Or mine (if I can find it, used but I think I've got the gasket and everything, i'd check before and make sure if you're interested) for $20 shipped. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Blk2.5GT Posted March 25, 2011 Share Posted March 25, 2011 Why pay the extra dough for the name? I heard that the ERZ/CNT DP are on back order for 3 weeks because the quailty is on the same lines as Perrin, Invidia and Cobb. I rather spend $325 (for catted) or so then those other prices! Hell you don't see the thing and you don't have to worry about the fitment issues that I have heard about with the Invidia as well. I'm going to be running my DP with a Turbo XS flex up pipe and a Magnaflow CBE...can't wait till stage II. Link to comment Share on other sites More sharing options...
executor485 Posted March 25, 2011 Share Posted March 25, 2011 Tis true, nothing wrong with an ERZ/CNT DP. I havent used one personally, but there have been good reviews on them. I hadnt even thought of it because OP was about perrin vs invida If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted March 26, 2011 Author Share Posted March 26, 2011 Why pay the extra dough for the name? I heard that the ERZ/CNT DP are on back order for 3 weeks because the quailty is on the same lines as Perrin, Invidia and Cobb. I rather spend $325 (for catted) or so then those other prices! very true but why pay the extra money to have a catted pipe i can pick up a catless invidia from iag for $299 and i dont have to pay for shipping or wait for it to ship. Link to comment Share on other sites More sharing options...
executor485 Posted March 26, 2011 Share Posted March 26, 2011 Nothing wrong with that. Your money and time, get what you want and when you want it. Catless is nice, only issue is if you're in an area that requires them it can be a pain when inspection time comes or whatnot, but I've not had any issues. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Blk2.5GT Posted March 26, 2011 Share Posted March 26, 2011 Have fun smelling exhaust fumes... Link to comment Share on other sites More sharing options...
Blk2.5GT Posted March 26, 2011 Share Posted March 26, 2011 Ohh, I forgot to mention I got a quote for the CATTED CNT DP for $299 shipped when they arrive in 2-3 weeks... Link to comment Share on other sites More sharing options...
GTTuner Posted March 26, 2011 Share Posted March 26, 2011 I think the divorced area has more to do with what turbo you have. I never had a problem with a VF40 interfering. Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 26, 2011 Share Posted March 26, 2011 Ohh, I forgot to mention I got a quote for the CATTED CNT DP for $299 shipped when they arrive in 2-3 weeks... Catted CNT MT DPs for $240 shipped here: http://legacygt.com/forums/showthread.php/cnt-catted-mt-down-pipes-240-delivered-con-us-158142.html Personally I'm happy with my Cobb DP (2.5" taper and all) , but if I were in the market now, it'd be CNT all the way. Link to comment Share on other sites More sharing options...
executor485 Posted March 27, 2011 Share Posted March 27, 2011 Have fun smelling exhaust fumes... Yea, I dont have that issue, 3 years runnin strong. Thanks though If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted March 27, 2011 Author Share Posted March 27, 2011 yea im not to concerned with the exhaust fumes even if i do smell them. also i live in an area where all they have is emission inspection and as long as your obd II with no codes they dont check your exhaust at all. Link to comment Share on other sites More sharing options...
GTStage2 Posted March 27, 2011 Share Posted March 27, 2011 Talk to Jeremy at Fredbeansparts. He can do better on that price there. very true but why pay the extra money to have a catted pipe i can pick up a catless invidia from iag for $299 and i dont have to pay for shipping or wait for it to ship. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted March 27, 2011 Author Share Posted March 27, 2011 ok thanks a lot man ill give him a call Link to comment Share on other sites More sharing options...
GTStage2 Posted March 27, 2011 Share Posted March 27, 2011 Mention that you are a member on the forum as well! He's a good dude and knows his stuff, takes care of everything quickly Link to comment Share on other sites More sharing options...
